the foil like material on lipos
2 Attachment(s)
if i barley press on the foil like material on my zippy with my finger nail it will dent. is there any protection between that and the actually battery material. i have 1 inch wide velcro straps that seem to dent it as well, when i crash. i really dont want to blow up my first 105 buck pack and melt my revo, unless i get it on tape:lol:
No - thats it....
The foils is basically the cell. You dont want to tear that. Denting it is not really good either. When you dent the pack it creates a little spot on the pack that can cause a small fault inside the pack and it creates a small little hot spot so to speak. You should avioud denting it if you can.
That said... I have a nuumber of pretyy old pretty beat up packs that havent blown up or anything, I dont think those little dent s you showed in your picture are going to cause a meltdown, but beating a pack up to much will likey reduce it lifespan. I like to put an extra layer of shrik wrap over may packs for 2 reasons. A little extra protection for the cells is one, and then when the shrink starts to look beat up and worn and torn (which it eventually does) I can take it off and put a new layer on it. It keeps the original manufacturers wrap in better condition. |
I would suggest wrapping it in re-inforced tape, then adding an extra layer of thick shrink wrap.
You definately want some more protection on that cell. One or more layers of shrink would be suggested. |
ok so i should just reinforce the original shrink wrap with more tape and shrink wrap. what is the thickest shrink wrap.
should i try a rubber mat like material or just try and make a case for it? what do you guys do for a case this is my first lipo and i never realized how fragile it was, seems like driving with a water balloon for power ready to pop |
were can you order more shrink for the pack?
Sikeston34m had some decent shrink at one point, give him a yell! |
my zippy -r (the white ones) seem really solid. 3 layers of shrink (i think, at least 2) but im considering adding another. where can i buy this, im international, so HK is usally the cheapest.
i had dented my pack with a 3m screw.. :( got some maxpuffs heatshrink and it worked like a charm :D
...now i need camo duct tape |
For you Eli, I got some really nice thick stuff from Al's Hobbies that is perfect for those Zippy packs of yours. Its yellow, but who cares about the color. |
I started wrapping mine in electrical tape after I damaged some of the shrink wrap. Works great.
| All times are GMT -4. The time now is 01:04 PM. |
