Help programming the MGM!
I did not have any brakes on the controller, so I tried to re bind the controller to see if that would help...No luck. Now when I turn it on all I get is a continuous beep. My instructions are not w/me presently. Can someone walk me through rebinding it...Is it the same as the mmm?
Thanks |
Of course I need the buggy tomorrow and I am having trouble....:tongue::tongue::tongue::tongue::tongue ::tongue:
They should have instructions on the website.
I checked their site...could not find my prob. listed.
Someone should copy all threads like this to the CC section! Those whiners that keep complaining about failed MMM need to see this. There are other options available but they're a PITA!!! I have seen so many threads like this, I remember one guy was offering $100 if someone could walk him through programming his controller.
The controller was running fine in the dirt...I did not need brakes really so I did not fuss w/it. But, where I am going tomorrow I NEED a lot of brakes.
As I stated above, the controller just beeps constantly. |
I know it has been a while guys...I really need some help...I'll check back in the morning..
Continuous beep means EPROM error and will need to program again. Make sure endpoints are 125% according to MGM for best results. Hold full throttle, turn on controller, wait 10 sec (forever), should hear 3 beeps, hold full reverse, 1 beep, neutral, 2 beeps, turn off controller.
Thanks for your help bdebde!!!
Finally got it to go today...I need more bakes...in setting the brakes, as you are looking at the screen, the harderst setting is at the right side...correct... it does say hardest so I am figuiring that the futrhest to the right is the strongest setting
Yep, all the way to the right is the hardest brake. I think mine is at "very hard1" to get good brakes.
| All times are GMT -4. The time now is 06:44 AM. |
