-   -   Wheel for slash (https://www.rc-monster.com/forum/showthread.php?t=15173)
david lamontagn 09.21.2008 12:34 AM
Wheel for slash
which wheel can i buy to put on the traxxas slash???? I need wheel with a 12mm hex.
I want new wheel to put proline badland 1/10 tire.
Thank you:wink:
lincpimp 09.21.2008 12:39 AM
Any 2.2 wheel, like the stock old pede wheels. You will have to have the different offset front and rear wheels to keep the track width correct.
Front: http://www3.towerhobbies.com/cgi-bin...?&I=LXJF50&P=7
Rear: http://www3.towerhobbies.com/cgi-bin...?&I=LXJF49&P=7
You can get them in white to and dye them. I use the fronts on my crt.5 all around with gladiator tires and they work great.
rootar 09.21.2008 12:29 PM
hold on there linc there is only a .125" difference offset on each side of the slash, i would use 4 front wheels, like i have with the badlands tires. and btw the body is gonna need ALOT of trimming to keep from destroying the tires. the whole setup will give you 3/4" more width which really helps
check the pics out in here
http://www.rc-monster.com/forum/showthread.php?t=13921
rootar 09.21.2008 12:33 PM
if you used the stock pede wheels the front would be 1/4" wider than stock and the rear would be 1/8" narrower
david lamontagn 09.21.2008 01:24 PM
rootar, you use nitro star 5 spokes wheel on your slash, right??? and you use 4 front one, right??
Did you use the gray hex on the rear??
david lamontagn 09.21.2008 01:27 PM
is this one Rootar? nitro rustler front wheel??
http://www3.towerhobbies.com/cgi-bin...?&I=LXZS53&P=7
rootar 09.21.2008 03:14 PM
yea the 5 stars, youll need the stcok black rear hex on the slash not the grey ones that was a mistake as it only made the width difference greater
Arct1k 09.21.2008 04:04 PM
How about the 30's Badlands....
http://prolineracing.com/images/PRODUCT/medium/539.jpg
http://prolineracing.com/p-539-badlands-30-series.aspx
