-   -   Covering the holes on the rear of the Medusa motors...what to use? (https://www.rc-monster.com/forum/showthread.php?t=15476)
magman 09.25.2008 09:10 PM
Wondering what you all are using to cover the holes in the rear of the motor...looking for ideas
bruce750i 09.25.2008 09:57 PM
Nothing on road, off road just put some tape over them. The tape also grabs small dirt that gets in from the front. It's better than nothing. Or find a plastic bottle cap and make it fit some how?
magman 09.25.2008 09:58 PM
Not a bad idea w/the bottle cap..
E-Revonut 09.25.2008 10:05 PM
I've seen someone use a piece of plastic on the back and use a piece of shrink wrap to hold it on.
brushlessboy16 09.25.2008 10:09 PM
neu endbell cover?
jhautz 09.26.2008 01:36 AM
Havent seen them in use yet but here is a new option.
http://www.outerwears.com/proddetail.asp?prod=202450
lincpimp 09.26.2008 01:49 AM
Old sock, and a bread tie....
Wash the sock well, cause I am sure the hot motor will bring the smell out...
Dammm, yo buggy smelz like so ol' stank azz foot, whats rong wit yo self? All out on da track tryin to represent with dat smelly chit, yu no gansta, yous a posa! Now gets to steppin!
jayjay283 09.26.2008 02:02 AM
yeah I bought some like 80mm shrink wrap off habrofreight.com. im scared to shring it whaT IF IT GRABS MY HAND AND///// I AM fREEDY kREUGER BRUSHLESHLESS HAND
rootar 09.26.2008 07:47 AM
you could use and rcm heatsink clamp but cut out a plastic or aluminum disk that covers the holes and put it under the rear clamp so that it holds it on there, now you have a heatsink and dirt cover.....im sure somebody else already thought of this but i dont remember who it was.
Gee 09.26.2008 10:45 AM
The cap off a plastic gallon of milk fits the 36mm motors pretty good. Drill out three holes for the wires and slide them through it. I used a piece of cloth tape around the end of the motor and push the cap on there. Then trimmed the excess tape. I can't find any pictures of that incredible idea. It works fine, looks a little funny though. I took it of a while back when I found this tape at a thrift store for a couple dollars. It's the aluminum type tape they use for heating/cooling duct work and furnaces. It has no problem sticking on the motor and handles the heat the motor puts out. I got it on the front and back of the medusa and put it on the back of one of the Neu motors also. If anyone wants to try some just pm me. I can cut some off and put it in and envelope. Lick it, stick it, ship it. I don't know what a role would cost at the hardware store. There's a lot on this roll.
http://i212.photobucket.com/albums/c...s/DSCF6314.jpg
http://i212.photobucket.com/albums/c...s/DSCF6317.jpg
http://i212.photobucket.com/albums/c...s/DSCF6311.jpg
You can tell where the cloth tape and milk cap use to be on the end of the medusa.
http://i212.photobucket.com/albums/c...s/DSCF6312.jpg
bruce750i 09.26.2008 10:55 AM
Gee thats the stuff I use.
Gee 09.26.2008 11:50 AM
If your still using it I guess it working for you too. You been using for very long? I just found it about a month ago and tried it. Never really thought about the heat issue of a peice of this vs a plastic cap. I would guess this would be better for the motor heat.
Sammus 09.26.2008 11:55 AM
I cut out an 0.05mm alu disc and put it in a dremel mandrel, spun it in the drill up against various abrasives till it was perfect circle, then thermal epoxied it to the back of my Ammo motor (big holes at the back). Works a charm ;)
Gee 09.26.2008 11:59 AM
That a good idea to. I have a problem cutting circles correctly unless I have a jig of some sore. Using the drill to get the shape might improve that for me.
bruce750i 09.26.2008 12:01 PM
I used it to fix or balance cheap Helli blades. And sometimes when I'm in a pinch photo tachometer paper.
