-   -   Feigao 540C 9L? (https://www.rc-monster.com/forum/showthread.php?t=1551)
WheelNut 11.13.2005 01:42 PM
Feigao 540C 9L?
Has anybody got this motor yet? I might be getting a basically stock Emaxx to mess around with this winter and I will need a new motor for it. This looks like a perfect motor for my application, but what have you guys found? I'm not looking for huge power, good run times and as much or more power than a Novak HV-maxx system. I've got a MGM 12012 controller so I'm limited to 12 cells (not that I would use more any way). It looks like the old sytle 540 9L would work good as well, but of course I'd need a motor brace and all that for it, so it would be more expensive. Also any andvice on gearing? What size of pinion would you recommend with stock size tires?
Thanks.
nbcaznmaster 11.13.2005 01:51 PM
well, mike's heatsink is also a motor brace!! The heatsink is worth the price alone!
WheelNut 11.13.2005 01:52 PM
Yeah, but the C motors have a heatshink built into the can...........and they are the same price as the old purple motors....;)
nbcaznmaster 11.13.2005 02:11 PM
true, but nothing beat's mike's quality in his products, and his servocie. But its all up to u! dont forget the 540c has a higher rpm arattings then regualr. SO that might help/hurt ur setup depending on ur car.
Serum 11.13.2005 04:09 PM
I thought they are a bit more expensive? i could be wron though. The preformance will be the exact same as with the normal 9L
phildogg 11.13.2005 07:05 PM
so they are basicly the same motors? the c9L and the 9L
phil
nbcaznmaster 11.13.2005 07:16 PM
almost, except with heatsink.
MetalMan 11.13.2005 07:37 PM
And the rear enbell that can be unscrewed to gain access to the bearings and rotor.
WheelNut 11.13.2005 08:53 PM
And the 9L is a good motor for a Maxx on 12 cells correct?
nbcaznmaster 11.13.2005 09:05 PM
yep! can handle 12-16 cells.
MetalMan 11.13.2005 10:22 PM
16 cells is pushing it though. I would say 14 cells max, but is okay for the occasional 16 cells.
phildogg 11.14.2005 06:56 PM
I used to have a 9l on 14cells and it ran great. 16 would prob be too many.. trying not to get back into the trucks but looks like I'm back. LOL
phil
dabid 11.15.2005 02:23 AM
phil
I've heard that the "C" motors (well, at least the 380 ones) are a bit faster than the non finned ones.
nbcaznmaster 11.15.2005 07:39 AM
isn't every1 in this site famous for pusshing the limits? lol
MetalMan 11.15.2005 08:14 PM
Not past their 50,000 RPM limit, but for pushing the limits of their vehicles instead.
