-   -   What are you guys running in your truggies. (https://www.rc-monster.com/forum/showthread.php?t=15540)
Gee 09.29.2008 06:00 PM
I just converted the Kyosho inferno truggy. I was curious about others truggies setups and if your happy with it.
I am running 4s on a MM/BEC - 1515 1y /s 48/19 right now.
The Axial .28 engine that I took out had lots of power. It's a big truggy so is it going to need more lipo to make me go WOW? I have the same setup on my G3R except it has the single speed tranny and spur/pinion of 56/26 right now. It makes me go WOW and we've been together for almost a year now.
What are you others using in your truggies? Are you happy with the power you have? Any recommendation (besides counseling) for me to put the spark back in my relationship with the truggy?
TDC57 09.29.2008 09:05 PM
I'm running a MGM controller, Neu 1515 1y F and i'm using 46/18 in my XT8 and runs great, stays supper cool on 4 & 5s. :yes:
Highly recommend this setup, :wink: that a pair of High heels always seems to get the spark back in the relationship http://www.pierresilber.com/highheels14.html :lol::lol:
gimpygolden 09.29.2008 09:18 PM
I've got a Medusa 36-60-1600 on 5s in my ST-rr. My MMM smoked during configuration so I don't yet know how she runs. Hope to have replacement soon.
Gearing is 18/50.
stum 09.29.2008 09:34 PM
Ill swap you my 1.5d for your 1y it will make you go wow on a 4s lipo config.. in fact I can't use it in my 8ight conversion as it will be with teh smallest gear set for 60mph which is retarded. It is perfect in my erevo due to more gearing options.. 50mph is not an issue, but on the track 40-42mph is the best speed.
Gee 10.01.2008 12:32 AM
Thanks for the offer stum. I think I will stick with the 1y.
Thanks for the replies. I will keep messing with it. I really haven't put a whole lot of time on it since the conversoin. Been busy and got the 8ight roller right after hte buils. The speed calc give it around 50mph with that setup but it doesn't seem like it. It might just be me comparing it to the Axial .28 I had in it. That had a lot of power. If I was looking for a reason to go past he 4s line and get an esc that can handle it. It looks like the truggy will be the reason.
big greg 10.01.2008 09:41 AM
yup 4s with the 1y is all you need, super cool temps, and amazing speed, i love when nitro guys drive mine, the first word is "wow"
cornolio 10.01.2008 04:18 PM
im running a 1515 1y on 4s too.im very happy with the speed.anything faster could not be driveable.check your gearing if you find it slow for you
jhautz 10.01.2008 06:29 PM
I love the 1515/2.5D on 5s in my truggy. Flat out powerfull runs very cool.
Same setup Monster Mike runs in his truggy too.
Sylvester 10.01.2008 06:37 PM
Id love to run 5s on this exact setup, on my 4s flightpower 5000's the 2.5 runs a little hot, what esc are you using?
jhautz 10.01.2008 06:54 PM
MMM right now. 3rd one, but this one seems to be holding up for the moment.
cheesecake 10.01.2008 08:19 PM
im running a nue 1515/2.5d opn 5s with my 2nd mamba monster
Arct1k 10.01.2008 09:19 PM
I had a 1515 2.5D on 5s now running a 1515 1Y on 4s...
Semi Pro 10.01.2008 11:39 PM
Hot Bodies LSP pro with novak HV6.5 on 3cell
sounds underpowered but its perfect for the tight track we race on. runs cool with no fans and is soft on power
im actualy very happy with it,and its still faster than my revo conversion
stum 10.01.2008 11:42 PM
I'm running a 2.5d/f on 4s in my e-revo racing truggies and took 3rd in the last a-main (geared for just over 40), but I don't think I want to pull it out and I don't want to run 5s setups.. my 1.5d should work great on 4s considering a 4.3 ratio, with a 50t spur and 13t bell I'll be at about 43mph. Should run great.
Matthew_Armeni 10.02.2008 04:02 PM
In my Losi 8T always run 6s, MM, and either my Medusa 60mm 1300kv or a Neu 1515 1.5Y.
