-   -   Lipo's shipped and on there way. (https://www.rc-monster.com/forum/showthread.php?t=1555)
ryanvm777 11.14.2005 08:40 PM
I finaly broke down and bought some lipos. I also bought the Astro Flight 109. I purchased them from maxamps.com I purchase 2 18.5 4200 mah and the Thunder Power TP-205 Balancer Adapter, whatever that is. Dont know what I am doing yet, so you will here more from me when I get my truck running and ready to install the batt. Mabey I should check for fire insurance on my house and start off by charging them when my wife and the baby arent home. LOL.
squeeforever 11.14.2005 09:05 PM
why 18.5 volt packs? are you gonna run them in parallel? what motor are you running?
coolhandcountry 11.14.2005 09:10 PM
are you going to run them in parrelal or series.
ryanvm777 11.14.2005 09:29 PM
I have a 7xl and will be running them parrallel to have 8400mah.
nbcaznmaster 11.14.2005 10:04 PM
dang, thats some insane runtime then!
coolhandcountry 11.14.2005 10:15 PM
you must be trying for 20 mins:D let me know how that works out
ryanvm777 11.14.2005 10:36 PM
My E-maxx is to fun to only drive for 8 min at a time. I figured this way I can get my money's worth out of it (at least try) I am hoping for 20 min, but I tend to drive it wide open alot.
nbcaznmaster 11.14.2005 10:41 PM
lol, just make sure not to blow up the packs or there goes ur investment!
squeeforever 11.14.2005 10:48 PM
you should get more then 20 easy.
MetalMan 11.15.2005 08:07 PM
You should be able to get 30mins or more! BTW, if you ever plan on getting a balancer, then you will want a different charger. Most balancers won't function properly with the AF 109.
crazyjr 11.16.2005 12:04 AM
And it will run like a scalded cat.
ryanvm777 11.16.2005 12:11 AM
Well a different charger is almost out of the question. I just bought it on ebay for $101, and what axactly does a balancer do?
ttrmike 11.16.2005 12:16 AM
I can get 20 min of runtime on my 9l on 13 GP3300 cells in series.
MetalMan 11.16.2005 12:21 AM
It keeps the cells in a Lipo pack at the same voltage. It balances the cells during charge. The benefits of balancing are:
-Increased saftey (due to less of a chance of overcharge/overdischarge)
-Increased Life (cells are less damaged due to overcharge/overdischarge)
-Better performance during life (same reason)
-Less expensive in the long run (because of longer battery life)
A4DTM 11.16.2005 01:45 AM
can you please elaborate? I got two 109d's and four polyquest cells with PCM's..
