Balancing Taps.
hello all, im a little confused here, im planing on using zippy lipos here. They come with a jst-xh taps. I want to balence using a flightpower balancer. So if i buy these nessesities that i link for you it would work correct?
From flightpower balancer to this http://www.maxamps.com/TP4S-HYP-Adapter.htm then that tap goes to this http://www.maxamps.com/HYP-MULTI-ALIGN.htm then from the conversion board i connect the lipo tap and charge???? Can Someone clarify this for me. Anyone that uses zippy lipos can you tell me how and what you use to balance. Thanks mike. |
anyone can tell me please???
it looks like you got the right idea. my charger come built with a balancer already.
i use a hyperion 0606i charger with the lba10-xh balance adapter to charge my zippys. |
Jst taps are the same as the Align taps which is what I use with my Equinox ballancer. All you need is the adapter to go from Jst to Fp taps.
| All times are GMT -4. The time now is 10:11 AM. |
