quark pro
so ive got a quark pro(used)what is the thing to do for run on 6cell lipo????i know that i should add a bec but what about the wiring and the heatsink???any modd??
and the thing that i should not do.....(i dont want to melt the esc:lol:) |
5S used to be a bit hot or miss on this - heat sinking will depend on the condition of the internal thermal pads - They used to separate from the FETS and stop conducting heat - mike used to make a kit for modding them.
5s works fine.. 6s fully charged i heard caused problems. not sure if there was a fix for that or not. to get it to run faster, you can replace the thermal pad with a copper shim, w/ thermal epoxy.
what's mean???? |
sorry, my quark had a thermal pad holding the fets to the case. it's a few years old though, so I'm not sure if they changed it.
hold on, i'll try and find you my write up. |
http://www.rc-monster.com/forum/showthread.php?t=6529
give it a minute.. i'm uploading like 40 pics. |
You like trouble man....MMM x6 and now a Quark:lol: |
thanks A4DTM for the link...now i unterstand:yes:
dont worry david jai pogné un deal un 1515 2.5d top shape ak le esc(quark pro top shape)pour 200$ |
:whip::whip:
Mine never had issues out of maybe 10 packs running a 1515 2.5D on 6s, and about 15 minutes with a 1515 1y. I had the rcm quark heatsink and a 40mm novak fan, no caps or internal mods.
I guess i have been lucky, to have no problems with mine yet. Mine will cogg slightly on a 6s fresh off the charger, however, if you let the battery set for a day or two, mine works without incident. I prefer 5s with mine though. Current setup is, Neu 1515/2.5d/f, Quark 125, 4-5s lipo, G-Emaxx tranny w/strobe 51/20 through 1/8 diffs in a Gorilla revo. It runs maybe 20* above whatever the temp is outside, no matter how hard i run it. I love this ESC
Wow. Those temps are incredible with only 1 fan. Where's it on the esc?
| All times are GMT -4. The time now is 08:20 AM. |
