-   -   BEC of the 20120 Micro (https://www.rc-monster.com/forum/showthread.php?t=1563)
virusss 11.16.2005 07:50 AM
Hallo boys i received today my brushless setup Feigao 7xl 20120
micro controller and UBEC.I wanted to ask to you as it is made to deactivate the bec of the controller micro for being able to use the ubec external? Thanks to all
Dafni 11.16.2005 08:13 AM
If you want to disable the internal BEC, just remove the black jumper. (somewhere behind the red programming jumper, maybe you'll have to remove some of the shrink)
At least this is how you do it with the Warriors, but I'm quite sure it's the same on the Micros.
virusss 11.16.2005 08:14 AM
hallo dafni,thanks for reply i see the red jumper but i dont see the black...
Dafni 11.16.2005 08:17 AM
Like I said, it's somewhere behind the red one. YOu should "see" it through the shrink. Just remove some of the shrink.
virusss 11.16.2005 08:22 AM
i remove the shrink the red jumper is only jumper
virusss 11.16.2005 08:23 AM
ooopssss i see i see :)
thanks dafni
