-   -   Problem LI-PO cut-off (https://www.rc-monster.com/forum/showthread.php?t=1564)
virusss 11.16.2005 09:02 AM
Hallo boys i have a question, whit my setup 7xl-20120 micro, 2 packs of thunder power 3s4p 8000,the 20120 do not have the cut-off adjustable, as I make not to unload the lipo excessive? They are not successful to find of the cut-off external for these voltages, the only one that I have found supports until 4C LiPo.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJDJ0&P=7
MetalMan 11.16.2005 09:40 AM
How about this one:
http://66.241.195.91/lithium/lithium.asp?path1=lithium
virusss 11.16.2005 10:08 AM
Saver works with 2-10 series cell packs :(
I have 6s lipo=18 cell classic
MetalMan 11.16.2005 10:13 AM
The Li-Saver works with 2-10 Lipo cells.
virusss 11.16.2005 10:14 AM
oooppps thanks much :)
crazyjr 11.16.2005 03:49 PM
Hey Metalman. The extra wire goes to the pos/neg of the battery, right.
squeeforever 11.16.2005 04:29 PM
what about then you dont want to run lipo and you wanna run nimh? if i were to use something like that i would want it soldered. what would i do if i was to run nimh? just unplug i from the esc and the reciever and the esc up to the reciever like normal?
Serum 11.16.2005 07:17 PM
Yes, it does Crazy.
squee, what are you saying, it's a bit misty.. i presume it's about the one from towerhobbies you are talking about? seems to me like it's an auto sensing one..
MetalMan 11.16.2005 07:18 PM
Squee, yes, you would just unplug the LVC from everything and plug the controller in just like you would normally.
Serum 11.16.2005 07:27 PM
It just measures then, but it can't do anything anymore with that information..
