How do you fix it?
Hey guys.
I'm almost done putting together my MBX-5T. I've also mounted Mike's battery tray using a three pole screw holes. Could you show me how do you fix your battery tray to the chassis? |
I dont have one, but im pretty sure you bolt the blocks that come with tthe tray to the chassis, then bolt the tray to the blocks.
captain harlock - do you have the new or old battery tray? The new one is a single piece with a built in spacer... With either one though, you pick the holes you want to use in the chassis, and then drill matching holes in the battery tray. Make sure the holes are a little smaller than the screw, so that you can thread the screws into the plastic. :wink:
| All times are GMT -4. The time now is 01:17 AM. |
