23mm 40series offset wheels?
Does anybody know who makes 23mm 40series wheels with offset?
Thank you Daf |
I thought they were all the same except the proline wabash wheels, which are 1/2" less offset. You looking for more offset than standard?
I'd say the Wabash are negative offset, and the top pic you posted are standard... anyway, I'm looking for positive offset.
I tried the CHeyenne 40s and they rub, need more offset. As far as I can tell, PL has no offset 40s with 23mm hex. They offer the 1/2" offset for standard tires, but not 40s. Any ideas guys? |
23mm offset hex adapaters?
Something like this maybe?
http://www.rcplanet.com/v/vspfiles/p...VG-022B-2T.jpg |
That would suck, just bought the hex adapters for that project... but if there are no wheel options, I will have to go that way.
Anybody know if Tower has something like that?? Thank you Daf |
Not sure what car this is for...
These are for truggy/buggy http://www3.towerhobbies.com/cgi-bin...?&I=LXLUD7&P=7 http://www2.gpmd.com/imagel/i/lintc1750.jpg |
Hm, thanks. It's a TwinForce. I think the ones you found require this set-screw in the axle... Savage stuff would work. Or I could buy these, make a groove in them on a lathe and put an O-Ring over the pins. Would be just a band-aid though, and I need someting proper. It's a customers truck.
Got another suggestion? Thank you so far! Appreciated! |
Hmm says out of stock! Try on ebay as they have a store there...
Search this HPI Savage 23MM Wheel Extensions |
Thanks mate, you have been a great help!
No problem...
| All times are GMT -4. The time now is 11:40 AM. |
