GriffinRU what you think about Ez-Run 60A modding
I have bought Ez-Run 60A esc and l looked it closer and found that its potential good candidate for modding, it has seperate brain borad and pretty simple PCB for stacking them. I tried this ESC on 4S lipo with separate UBEC and it handeled it pretty well with Ez-Run 3000KV motor on onroad car. Esc get warm but motor gets hot after 5-10min free run. But outside is pretty cold too about 44F ~7c.
My idea was stack 2 ESC fet boards to parallel for Higher amp rate. Ez-Run use 12 in parallel NTMFS4833N mosfets 6pc on each side of PCB On specs fets looks pretty powerful so 60amp rate on ESC can be trooth |
| All times are GMT -4. The time now is 10:11 AM. |
