-   -   Wooooow!!!! (https://www.rc-monster.com/forum/showthread.php?t=1585)
virusss 11.19.2005 02:00 PM
Wooooow!!!!
Hallo my friends today I have tried mine savage with the Feigao 7xle' the BK micro 20120, absolutely fantastic!!! One fantastic power, duration of the batteries 15 minutes,it raises the front wheels to command optimal setup indeed,only true problem creed is the weight 6kg, if it weighed less he go fast and would consume less right?How I can make in order to lighten it, I must by force pass li-po? Thanks thousands
squeeforever 11.19.2005 02:57 PM
first off i would keep aluminum to a minimum.
virusss 11.19.2005 02:59 PM
mine savage is all original(Plastic), the true weight creed is given from the 16 cell
nbcaznmaster 11.19.2005 03:32 PM
welll, he got a 20120, so it can handle a bigger motor which woudl compensate for the aluminum.
virusss 11.19.2005 03:34 PM
I like the power of feigao 7xl, i need more runtime :(
coolhandcountry 11.19.2005 04:00 PM
The 8xl or 9xl would give you same power with less speed and more run time. Change of tires and rims is away to lose some weight.
virusss 11.19.2005 04:04 PM
what me councils like tires and rims, and 8xl for example which runtimes it makes to obtain me, whit 3300 gp 16 cell?
Thanks very much
coolhandcountry 11.19.2005 04:26 PM
I can get a bout 25 min on 16 cells gp 3700 with a 9xl. You can shave about a lb or so off with tire and rims change.
What kind of tires and rims are you running now?
SpEEdyBL 11.19.2005 07:16 PM
You can shave off the most weight by going lipo. Otherwise you just have to live with it. Maybe a 10L would be lighter, but then you would sacrifice some power.
