HPI Phaltlines Wheel Wrench?
I've had a set of phaltlines for a while now and have always used them with the included 17mm hex adapters. now i just put some ofna 17mm adapters on and i can't get my socket to fit inside the phaltlines to tighten them up. anyone know of a 17mm wheel wrench that does work with these wheels?
thanks. |
This one works for me.
I just use a ratchet with 17mm socket, my normal wheel wrench doesn't fit in there either.
i don't have a wheel wrench. i use a ratchet, but my craftsman doesn't fit. guess i'll hit home depot with a phaltline in hand, if not i guess i'll go with that axial. thanks.
There's also the Kyosho wrench, which is more difficult to find but is maybe $8. That's what I've been using for these wheels, otherwise I use a different 17mm wrench.
If i remember correctly, this will do the job too. http://www.neweramodels.com/item.cgi?part_id=1664.
That looks like it should work.
cen sells a 17/23 combo on e-bay for like $8 very thin walled works for me
Street-Maxx
well, i ended up with a thin walled socket for my ratchet. ran me $4. now i got my phaltlines on and as soon as the loctite sets, it's time for my street-maxx to see some speed.
http://home.earthlink.net/~webhost/t...treetmaxx1.jpg http://home.earthlink.net/~webhost/t...treetmaxx2.jpg http://home.earthlink.net/~webhost/t...treetmaxx3.jpg http://home.earthlink.net/~webhost/t...treetmaxx4.jpg http://home.earthlink.net/~webhost/t...treetmaxx5.jpg i've got it geared for 45ish right now (26/56). should be hot but i'm only gonna run it a few times. |
| All times are GMT -4. The time now is 12:24 AM. |
