Project: Battle Truck, MGT 8x8
Ok guys, I have a feeling you're going to like this one. I've got a MGT on it's way (parcel post... UGH!) So it should be here late next week, probably thursday or friday. It's already been converted to brushless using a KB45 motor. Although, I'll completely be stripping down this MGT and using it for parts. I'm also working out a deal for a complete MGT 4.6 roller. RTR without engine. Here's the plan: I'm going to remove the diffs and put 4 outrunners in their places, all rewound to ~180kv for operation on 3s each. Yeah, that's right... 4 motors, 4 esc's, 4 batts. Here's what i plan on running on each axle:
http://www.hobbycity.com/hobbycity/s...less_Outrunner http://www.hobbycity.com/hobbycity/s...Simple_50A_ESC http://www.hobbycity.com/hobbycity/s...idProduct=6501 RX pack: http://www.hobbycity.com/hobbycity/s...idProduct=5552 Here's what I got for the operation: Differential Ratio: 1 Transmission Ratio: 1 Other Ratio: 1 Spur Tooth Count: 1 Pinion Tooth Count: 1 Total Voltage: 11.1 Motor KV: 180 Tire Diameter (inches): 7 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor coil Ω: 0 Spur/Pinion Ratio: 1 : 1 Total Ratio: 1 : 1 Tire Circumference (inches): 21.99 inches (558.58 mm) Total Motor Speed: 1998 RPM Vehicle Speed: 41.61 mph (66.84 km/h) Estimated Adjusted Speed: 39 mph (63 km/h) - 5% loss Effective KV Value: 180 KT constant: 7.51 oz-in/A Motor Torque: Amperage not specified... Final Torque: Amperage not specified... Final Power: Amperage not specified... I think this will be a fun setup, to say the least. Input? Oh let me get to the firepower. I was thinking one of these because it fires at a decent FPS, and holds a lot of ammo, as well as it looks like there is alot of plastic that can be removed. http://www.walmart.com/catalog/produ...ct_id=10248640 Also, going to do a rotating rocket mechanism, mounted to the top of the cab. I'll get some pics when the first MGT gets here. If you have a complete rolling chassis MGT for trade for BL stuff shoot me a PM!! |
Looks awesome dude, should be pretty crazy! Cant wait to see some pics of it!
Thanx! Can't wait either.
You will need to take lots of pictures of this! How do yo plan to set up the wheels and the steering?
The outrunner will (hopefully) directly replace the differential without too many issues/modifications. The motor shaft will come out both sides equally, and I'll probably have bearings supporting them. The shaft will mount into the CVD joint right where the differential shaft would've gone. Steering will not change at all from the stock setup.
Braking?
Should be a very interesting project indeed. |
I would run a direct to diff setup with one outrunner for each pair of diffs. I assume you will run a steerable wheel setup at the front and rear, and have 4 wheels in the center close to each other. That way you could run a 6s compatible 4130 size outrunner (pair of them) and a pair of MMM's for full foward/reverse/ and brake. This will be a heavy vehicle, but will require a minimum of fabrication. Just make a center piece that will attach the two trucks together via the skid plate area, with the back, non steerable wheels together. You will also need some sort of upper brace to tie the top of the bulks together, but flat stock should work fine. Steering could be handled with a simple y cable, as the steering wheels will have to turn opposite of each other to pivot around the fixed wheels in the center. Making decent motor mounts will be important, and supporting the non mount end of the outrunner with a bearing is a decent idea. |
http://www.hobbycity.com/hobbycity/s...utrunner_235Kv http://www.hobbycity.com/hobbycity/s...imple_100A_ESC http://www.hobbycity.com/hobbycity/s...idProduct=7639 Differential Ratio: 3.3076923076923075 Transmission Ratio: 1 Other Ratio: 1 Spur Tooth Count: 1 Pinion Tooth Count: 1 Total Voltage: 22.2 Motor KV: 235 Tire Diameter (inches): 7 Tire Ballooning (inches): 0.5 Motor Current Draw: 0 Motor coil Ω: 0 Spur/Pinion Ratio: 1 : 1 Total Ratio: 3.30769 : 1 Tire Circumference (inches): 25.13 inches (638.37 mm) Total Motor Speed: 5217 RPM Vehicle Speed: 37.54 mph (60.3 km/h) Estimated Adjusted Speed: 36 mph (57 km/h) - 5% loss Effective KV Value: 235 KT constant: 5.75 oz-in/A Motor Torque: Amperage not specified... Final Torque: Amperage not specified... Final Power: Amperage not specified... |
Here's what I plan on doing for a RX pack:
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack http://www.hobbycity.com/hobbycity/s...w_Voltage_horn |
:gasp: Wow.. this is going to be a fricken GREAT build to watch..:yipi: best of luck with it.. :intello:
Hay BL..:whistle: can you post any pictures in Project X threads ??:neutral:? I still cant..:no: anyway looking forward to future updates.. :yes: :yipi: Hope to see you tomorrow.. (I've got a six pac of soda with your name on it) :wink: |
Thanks!
I can't wait to see it come together. What's say we have a formal all-out battle at the november bash??? Weapons allowed, last truck standing wins! How's that sound? I'll try posting a random picture: http://i10.photobucket.com/albums/a1...r/pichers1.jpg |
No dice. I had [IMG] tags around it and everything.. Weird.
sweet, i cant wait to see how the motors fit in the diffs
| All times are GMT -4. The time now is 03:35 AM. |
