-   -   Muggy has arrived (https://www.rc-monster.com/forum/showthread.php?t=15949)
cembom 10.18.2008 02:25 PM
Muggy has arrived
Well my muggy got here. I wasn't sure if I should put it in the nitro area as its not brush less yet. I have some major plans but I have too collect on a few debts before anything starts... Well I snapped a few pics then the batts in the cam died. I dont have any hex drivers on hand so I cant disassemble it any further as I would like too so I can clean it. It has some pretty nice nitro parts if there is such a thing, they should get some of the costs on ebay. if anyone wants more pics I will get them but any good detailed ones will have to wait until I get a set of drivers.
http://farm4.static.flickr.com/3021/...e24a249c_m.jpg
http://farm4.static.flickr.com/3002/...fe6dda04_m.jpg
http://farm4.static.flickr.com/3010/...7bd7d42a_m.jpg
http://farm4.static.flickr.com/3219/...00a63619_m.jpg
http://farm4.static.flickr.com/3143/...505704bf_m.jpg
http://farm4.static.flickr.com/3158/...b5149bdd_m.jpg
DiFabio42 10.18.2008 02:28 PM
Sick! I always wanted to make a Muggy/8ight-T/8ight oe something like that Brushless. I will eventully.
cembom 10.18.2008 04:07 PM
Yup, I am not sure If I got my diff ratios right but I am going to try this setup:
Differential Ratio: 4.09
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 11
Total Voltage: 18.5
Motor KV: 2900
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.003
Spur/Pinion Ratio: 4.18 : 1
Total Ratio: 17.10364 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 53650 RPM
Vehicle Speed: 54.12 mph (86.94 km/h)
Estimated Adjusted Speed: 50 mph (81 km/h) - 7% loss
Effective KV Value: 2900
KT constant: 0.47 oz-in/A
MGM Compro 160 amp, 18 cell brushless car controller
http://www.rc-monster.com/prodimages...ite%20size.jpg
1521/1D 2,900 16.93 3.3 0.003 5.5 60K 1,750 watts 3,500 watts 21 volts
http://www.castlecreations.com/produ...sizes-1500.gif
cembom 10.20.2008 03:29 PM
Well I got some wrenches today and started too tear down and clean the muggy. Tons of nitro mess. I was planning on running it nitro until I compiled all of the necessary electronics but now I am reconsidering:lol:. Well I need too start selling things, I have a bunch of wheels and tired I got with it that I dont need. Anyone want two sets of muggy tires and a set of hubs? What about 40 series CF's on Wabash wheels? I am not going to sell the engine until I have every thing ready too drop in. Do you think a neu 1521 2900 kv would be too high in here?
http://farm4.static.flickr.com/3164/...0dc083cf_m.jpg
http://farm4.static.flickr.com/3251/...97ca3fc5_m.jpg
http://farm4.static.flickr.com/3167/...8a226416_m.jpg
http://farm4.static.flickr.com/3220/...c4502dbc_m.jpg
http://farm4.static.flickr.com/3009/...49ca1325_m.jpg
http://farm4.static.flickr.com/3062/...5c9c641b_m.jpg
http://farm4.static.flickr.com/3171/...0abb1e57_m.jpg
bdebde 10.20.2008 10:17 PM
I would use the 1521 1Y (1577kv), mine does great on 1515 2.5D (1650kv)
DRIFT_BUGGY 10.20.2008 10:51 PM
Sweet, keep us updated
drkdgglr 10.21.2008 03:45 AM
Funny,
I am in the exact same process of converting a Muggy. I am keeping the Muggy wheels/tires though. I sent Mike an email if he could make a motor mount which places the motor above the center diff. That way I can run split lipo packs, 6,8 or 10s. I'd lose mechanical brakes, but I wasn't planning on using them anyway. I hope he replies soon...
masense 10.21.2008 04:09 AM
I agree.
ratio 4.09
1521 1900kv
12/46
proline badland
16018 7s
16018 is a lot of capacity.
I think that it is 1,521 1Y (1577kv) best fitting.
The mechanical brakes are usable when I use the big pinion in 1521 1Y (1577kv).
Unsullied_Spy 10.21.2008 05:47 AM
Congrats on the Muggy, they're a great truck. If you're going with a 1521 go with a bigger pinion, I ran a 13T on my 1515 and it worked very well. Definitely get the 1Y if you are getting the 1521, and make sure your lipos can put out 120 amps for ~10 seconds or so (more is better, but that's the minimum I'd run).
The 16018 is a good ESC, I run one in mine and it seems to do really well (mine was just mounted with 2 zipties going crossways, kinda tacky but it held it in really well).
cembom 10.21.2008 04:33 PM
Thanks, I was thinking that with the motor being bigger that I could run the higher kv and still have the needed grunt. I was also liking the kv too run with 4s.
Unsullied_Spy 10.21.2008 11:19 PM
I wouldn't run the high KV one, stick to the 1Y. It'll run cooler and pull a TON fewer amps.
