-   -   Is ONE 10w 100 ohm sandbar okay on the +5v bar? (https://www.rc-monster.com/forum/showthread.php?t=16004)
e-mikey 10.20.2008 10:05 PM
I just made my first power supply but I used one 10w 100 ohm sandbar on my +5v rail. It's not getting hot and seems to be working fine. But I noticed there where 2 load resistors on my old one.
Will only using one 10w 100ohm be okay?
P.S. My output is only 11.6 :no:
e-mikey 10.20.2008 10:19 PM
I'm charging 4s on a hyperion 0610i duo. The PS is 12v 13A.
clowkoy 10.20.2008 10:38 PM
You need at least 10 ohms 10W resistor. It will only yield around 11.5 volts on the 12-volt side. You need a 10% load on the 5-volt side to have a good 12+ volts output. I used 6 x 10 ohms 10W in parallel in my PS and voltage does not drop below 12.1 with 12A load.
e-mikey 10.20.2008 10:50 PM
Perfect, thank you. I'll be picking them up tomorrow.
MetalMan 10.21.2008 01:06 AM
Re the 10W resistor not getting hot -- V=IR -> 5v=I * (10ohms) -> I=0.5amps -> P=VI -> P=(5v) * (0.5amps) = 2.5watts
