Neu 1512, 1.5d (3300Kv) on 4s in crt.5
I want to make a killer bashing crt.5 and i have a Neu 1512, 1.5d, a MMM V3 on the way:whistle:, and presently, i have a TP 5000, 3s, but i want to go with 4s.
Do you think that this motor will do the job just fine on 4s or should i stay with 3s and put a bigger pinion??? I know that this motor pull alot of amps (135A) so i consider that run it on 4s will lower the temps and give me longer run time??? But i have a Neu 1509, 2.5d (2700Kv) too, maybe i'am better to put this 1509 on 4s in the little crt.5 and keep the 1512 on 3s in my slash:neutral:?? Don't know what to do:oh: Thank you! |
i think either will be fine - i'm not sure you will actually get that current as the motor is not going to be stressed in a crt.5.
My 3300 kv 50mm medusa runs fine on 2-4s... |
The crt.5 is under 5 lbs i think so this motor will have less load than on a truggy. Thank you! |
I'm using a 1509 1.5Y in my CRT.5 and I can't keep the front wheels on the ground, I don't see any reason for a bigger motor.
On 2s, 3s or 4s??
That 1512/1.5d is going to be one beast of a motor in a crt.5 :tongue: Its a beast in a 1/8 buggy on 4s. Edumakated had his 1/8 buggy up to almost 70 mph on the 1512/1.5D and 4s.
You might want to make sure you have planty of tires on hand when you run it. I suspect you will be blowing them off the rims with very little effort.:yes: |
I like to ear this:yipi::yes::yes::yes: |
Good!! Hey Ryu James, which 4s lipo do you have???
I have Thunder Power since last year and i like this pack, but with the price of the Ziippy-R pack at UnitedHobby, i want to try this pack. |
I too think that is too much motor for the .5. I had a 3100kv little LMT 1920 on 4S that could do over 60, and barely keep the front down most of the way. See the Utube vid in my sig to see. I detuned to a 2200kv 50mm medusa and its still a wheelie monster if I load it enough.
That 1512 may be about undrivable in a .5. |
I think that i will try my Neu 1512, 3300Kv on 3s and see the performance and run time. i have an eagle tree so i will be able to monitor the amps drawn by the motor, and if it pull too much amps and the run time is too short for my taste, i will order a 4s pack.
I have my 1509 2700Kv on 3s in my slash and this little motor put alot of power in the slash and i think that the crt.5 is about the same weight than a slash. My slash is 6.1lbs now, with the FLM tranny case, Koolflight UBEC, badlands tires and LX one shock. |
I run Thunder Power extreme V2, 5000mAh, 3s in my slash and love this pack too:yes:
I think you really have to be insane to put a 1512 1.5D in a Crt .5, unless you are trying for the "fastest crt. .5." So I think you are better off with your 1509. It just doesn't make sense to take a car with a smaller footprint than a 1/10 st and have it be heavier and twice as powerful as a 1/10 st.
I had a crt.5 with a 1512/1.5d and ran 4s and it was simply awesome.Never got hot and it shredded tires highly recomended.
| All times are GMT -4. The time now is 09:14 AM. |
