-   -   Who Can rebuild Lipos? (https://www.rc-monster.com/forum/showthread.php?t=16045)
brushlessboy16 10.22.2008 06:51 AM
Im looking for someone to remove dead cell from my 5s zippy pack.. my momster ate it...:whistle:
Arct1k 10.22.2008 08:21 AM
da pimp...
lincpimp 10.22.2008 10:10 AM
Woot!
brushlessboy16 10.22.2008 06:19 PM
ok, i would need one cell removed...
Its an odd problem. all the cells are reading 3.87v except for one which reads 0.0v and i get no votage through the deans plug. like there is a physical break somewhere as there is no puffing or anything visible..
also i have one cell with a loose cover, not sure if its the cell casing itself or just a plastic film. the cell hold voltage well and is balanced with all other..
Thank you for the help
Arct1k 10.22.2008 06:23 PM
Sounds like a physical break all cells may be fine
brushlessboy16 10.22.2008 07:30 PM
http://i152.photobucket.com/albums/s...1022081829.jpg
http://i152.photobucket.com/albums/s...1022081830.jpg
http://i152.photobucket.com/albums/s...1022081832.jpg
http://i152.photobucket.com/albums/s...022081832a.jpg
http://i152.photobucket.com/albums/s...022081832b.jpg
http://i152.photobucket.com/albums/s...1022081833.jpg
http://i152.photobucket.com/albums/s...022081833a.jpg
hope this helps a bit
trev3813 10.22.2008 07:36 PM
Bathroom? water + lipo = BAD
lincpimp 10.22.2008 07:44 PM
That pack looks like the cells are soldered together. Showul be easy enough to seperate the cells and check them individually. I would remove the bad cell asap. Leaving a bad cell in the pack can kill the others...
What's_nitro? 10.22.2008 07:50 PM
Awe it's the middle cell too! That's a pain. Sorry for your loss(es). :cry:
brushlessboy16 10.22.2008 07:50 PM
since yesterday voltage in the cells has not moved.. im afraid to solder lipos :no: dont have a very steady hand
lincpimp 10.22.2008 07:54 PM
Oh that would be too easy to comment on....
Just use some tape to cover up the areas you are not try to heat up. Or send it to me...
david lamontagn 10.22.2008 07:55 PM
Parkingson + solders lipo = BOUMMMMMMMMMMM:lol:
brushlessboy16 10.22.2008 07:57 PM
yeah with you its either make things so bland that you wont comment, or make them so outrageous that it is blatantly obvious what can be said....
seemed to work nicely eh? :lol:
ill try and see what i can do..
seems like there is a plastic ladder-like thing in there.. hope it wont be a problem
brushlessboy16 10.22.2008 08:59 PM
AHA! I found it, the number four cell has its tab broken off..
lincpimp 10.22.2008 09:07 PM
You will most likely not have much luck fixing that, they usually break off too close to the foil to get to. Maybe a pic would help...
