Jato drive shaft on slash??
Can i use the Jato stock slider drive shaft on the Slash??
Yes. The Jato uses a larger U-joint though, so you'll need to drill out some plastic on your outputs and stubs or they will bind.
| All times are GMT -4. The time now is 08:07 AM. |
