estimated run time
here is my set-up (batts on the way)
rc8 w/ rc-m conversion medusa 36-60-2000 mmmv1 with 10+ races on it zippy-r 5s 4800s how are some of you calculating estimated run time it is geared for around 34mph using speed calculator any help would be appreciated here is a vidoe of my caster fusion also http://vimeo.com/1915910 |
Run time is so relative to the pull of your trigger finger that no one can give you a good estimate. Your best bet is to go practice and see where you are at. Of course lowering the start power and dialing in some punch control on the MMM will help increase runtime.
If its geared right I'll bet you'll see about 15 minutes. At least thats what I get on my Hyper 8
I get about 20minutes racing with 4s 30c 5k lipo's on my 8ight-e (tekno) with medusa v2 60mm 2000kv motor if that helps :) mechanical braking and I use the electri-clutch.
On a small tight track, this setup should get you well over 20 minutes as your avg speed won't likely break 18mph. On a larger track you'll probably only see 12 maybe 13 minutes as your avg speed should significantly increase. The power needed to reach faster speeds increases exponentially. This is because the mass of the vehicle actually increases as it accelerates but we don't need to get into that. At the end of the day, run times will significantly decrease on faster tracks. |
| All times are GMT -4. The time now is 09:38 AM. |
