.....Why are my tires spinning the wrong way?
Well, after I guess... stripping my rear diff, I purchased a new 16.8 EMaxx diff, off eBay...
After a couple hours of wrenching (never went this deep in the maxx, replacing something, so taking things apart was new....) I finally replaced it, my CVDs, everything.. Of course, nothing goes according to plan for me.. Today, I take it into my front yard, for some test bashing? Anyways, I plug it in on my porch..... I lift it up (I check the trim, and everything upside down, so it does take off, and break my leg, and a door... ) Anywho, when I push forward, the front end goes forward, while the rear end goes backward... Needless to say, the maxx goes NOWHERE. Could it just be a case of reversing a motor? Or did I put a front diff in the rear, if possible? ****Well, on a couple other forums, I received a answer on a couple other forums, would the problem be that the diff is flipped the wrong way? |
Flip your rear diff. That's your problem with the front and rear wheels spinning opposite of each other.
Thanks!
Looks like another hour or two of wrenching on the maxx... Hmm, let's see if I can be faster this time -.^ |
Don't feel bad, I did the same thing...a while back when I bought my first traxxas truck!
I can say that I've never flipped the diffs - well, actually once, but I flipped them both. Lukily all I had to do was swap two motor wires. :smile:
My achilles heel seems to be heatshrink. I am forever forgetting to put the piece on BEFORE soldering the wire to the deans. :oops: |
That's one of the good things about bullet plugs, you can always put the heatshrink on later :yes:.
Haha.
Well the first time took nearly 2 hours, after unscrewing some things.. Sheesh, you don't even wanna know. I pratically took apart the whole rear end... I sometimes do that... Unscrew whatevers in my way? :D Anywho, took probably 30 minutes this time! Boy, am I happy! Anywho, got a new problem! Check the other thread. :( |
| All times are GMT -4. The time now is 10:39 AM. |
