-   -   Tekno Neu 1515/1y/D/Q (https://www.rc-monster.com/forum/showthread.php?t=16126)
phatmonk 10.25.2008 11:38 AM
So do these new Tekno Neu Q motors bolt directly to the chassis where a nitro engine bolts on?Thinking about a 1/8 scale Serpent 960 conversion.Will I be able to use the Electri-clutch with a 2 speed clutch bell?:great:I will be using a MMM esc not to sure about battries
teknorc 10.25.2008 07:19 PM
Not all nitro engine bolt patterns are the same, but if you modify the chassis to 32 x 32mm mounting holes, the motor will bolt right up. These are direct drop-ins for the Tekno V3 conversions however and save the weight of the motor mount while lower the CG of the motor.
We may have a new Elektri-Clutch that will accommodate a big block 2 speed clutch bell in the near future.
BL_RV0 10.26.2008 03:09 PM
Cool, just like the Mega Car 8.
TexasSP 10.27.2008 10:05 AM
Not bad for a only a few bucks more than the others. I will keep these in mind for the future as it makes for a very clean install.
teknorc 10.27.2008 12:19 PM
Very clean? Like this? :)
http://impaktrc.com/images/TKR4015-3_4_close.jpg
