Center driveshaft options...
Looking at the options I have for center driveshafts. Wanted to use old emaxx driveshafts, as I have plenty...
However the pede tranny and the ax10 axles have 5mm inputs. While the driveshafts have 6mm id... Are there any yokes that will adapt or fit with some modification? |
the original t-maxx tranny has 5mm outputs, just get t-maxx 2.5 transmission output yokes and use them with the sliders and balls you want to use
http://cgi.ebay.com/Traxxas-4927x-Tr...d=p3286.c0.m14 , also, a locker for the pede tranny http://cgi.ebay.com/Traxxas-Slash-Ru...d=p3286.c0.m14 |
Thanks Harold, I actually had some of the 5mm id yokes laying around. Now i am that much closer to finishing the crawler.
James there is a guy on RCC that makes a direct replacement for the ax-10 tranny to run maxx shafts.
It works well and I plan to put some time on it as is. See how long it lasts... |
I am retard, I read that in the first post sorry. :oops:
Do you know if anyone makes a yoke that will fit on the axial axle pinion shaft and allow use of the old emaxx style driveshafts? |
You could get Mike to make you a pair of bore reducers.
I don't see the t-maxx yoke distorting, it might. What about grinding a second flat spot and two set screws? both sides of the yoke should be threaded, and you should be able to sneak a dremel in without disassembly?
The yokes are nylon, and that nylon won't hold threads of a machine screw very well (with the amount of torque placed on the set screw to keep the yoke on tight enough).
Will jato shats fit pede yokes? |
MIP makes some splined HD steel monster shafts for the AX10.
They are very heavy and strong, but a bit pricey. |
| All times are GMT -4. The time now is 05:04 AM. |
