CRT Diff Help
I have a fiego motor installed in my Brushless CRT. What diff oil should I use for help with ballooning the front tires? I installed a brand new set of tires this past weekend and exploded the foams in 1 of the tires.:diablo:
What are you running at the moment ? I run 10000 in my X2 CRT and it's spot on but throttle control helps as well :wink: Most run between 10000 and 20000 in there truggies . |
I started with 30000. What about front and rear diff?
Try 7 30 3 and then maybe you can work the middle down to 20 or 15 in due course....
I use a spool. I tried all thickness of oils and none of them stopped the front from ballooning. With the spools, I'm never worried about my front tires getting a beating like they were before.
i ran 20-30-1 in my crt it depends if you use it for racing. that setup males it very agressive on the track
the center diff gears are crap that come in it, i use 30k seems to keep it under control
i wouldnt say there crap you just have to shim them correctly. like in any car
compared to the losi gears, they are made of crappy cast aluminum, but they have held up just fine
here's a good thread that may help with diff tuning; http://www.rc-monster.com/forum/showthread.php?t=5050 |
| All times are GMT -4. The time now is 10:58 PM. |
