-   -   I killed it... MMMv3 bit the dust (https://www.rc-monster.com/forum/showthread.php?t=16234)
bustitup 10.29.2008 11:55 PM
Well I received my v3 replacement about two days ago and fired it up today.......
e-revo
1515/1.5d
no external bec just the internal one
two 3s zippy 4800mah packs in series
it started right up the first time and hooked up to my futaba 3pm 2.4 no problem......like a charm for about 15min..... real fast and suddenly just quit...I had it set custom at 19.2 volts cutoff....low timing......everything else was default except for soft start...kept checking temps after every two runs....batts werre about 150 esc was about 170....motor 150
took it in the house and hooked it back up to my pc and couldn't get it to recognize the monster....but notices that programmer thingy got real hot
real depressing
Silver_Flame101 10.30.2008 12:06 AM
Wow..... That is exactly what I did not want to here; a MMM v3 failure. Hopefully it was just a quirk.
MetalMan 10.30.2008 12:51 AM
Overgeared? MMM at 170 makes me think so. Your batteries weren't enjoying the punishment either, apparently.
George16 10.30.2008 12:59 AM
That's the first confirmed death of a V3.
BrianG 10.30.2008 01:00 AM
I think we are all just a wee bit over-sensitized to any MMM failure, but there are bound to be failures here and there, even with a solid product...
I too think the ESC was a tad hot, especially considering it has a fan. The fact that the link gets hot when you plug it in leads me to believe you smoked part of the brains.
bustitup 10.30.2008 01:37 AM
24/58
no smoke or fire...just quit
Cartwheels 10.30.2008 01:51 AM
Wow batts at 150* That is way hot for lipos.
hoovhartid 10.30.2008 02:16 AM
hey man,
I'm gonna go out on a limb here and say that gearing a 12lb truck for over 70mph....
...you're only gonna be able to do a few speed passes before a need for cool down.:whistle:
dude:diablo: you're mean to your electronics.
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333332
Other Ratio: 1
Spur Tooth Count: 58
Pinion Tooth Count: 24
Total Voltage: 22.2
Motor KV: 2700
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 0
Motor Current Draw: 120
Motor coil Ω: 0.004
Spur/Pinion Ratio: 2.42 : 1
Total Ratio: 12.61004 : 1
Tire Circumference (inches): 18.54 inches (470.8 mm)
Total Motor Speed: 58644 RPM
Vehicle Speed: 81.63 mph (131.12 km/h)
Estimated Adjusted Speed: 72 mph (116 km/h) - 11% loss
Effective KV Value: 2641.62
KT constant: 0.5 oz-in/A
Motor Torque: 0.31 ft-lbs
Final Torque: 3.95 ft-lbs
Final Power: 2664 watts (3.6 HP)
not to say I wouldnt still hold the camera and wear the shin guards:lol:
call me up if you need a videographer!
lincpimp 10.30.2008 02:50 AM
Originally Posted by hoovhartid (Post 227511)
hey man,
Other Ratio: 1
Total Voltage: 22.2
Motor KV: 2700
Motor coil Ω: 0.004
Jesus!!! And I though my 1521 1y on 6s would be a bit much... The tires must have been 8" diamter minimum at those speeds...
lincpimp 10.30.2008 02:53 AM
Just for comparision I run a 1515 1.5d in my erevo on 4s lipo geared 19/50. It does over 40mph and never breaks a sweat. It does work a pair of trakpowers pretty good though... I have a pair of fp 4s 3700 packs that I plan to run in parallel, that should provide plenty of juice.
Andrew32 10.30.2008 03:13 AM
yea, a 1515 1.5d on 6s is a bit much...ESPECIALLY AT THAT GEARING!
I run the 1515 1.5d on 4s with 24/62 is goign 45+...
and are your batteries the 15c zippy? sounds like they are COOOOKING
auto2 10.30.2008 07:18 AM
yea overgearded BUT a MMM should shut itself off if it gets too hot no matter what is going on wrong around it.right?
Dagger Thrasher 10.30.2008 07:28 AM
Ouch, that sucks. Those temps are way too hot, though! The MMM doesn't thermal until it hits around 220F, but judging by the temps of those cells, I'm thinking that maybe ripple voltage killed the MMM? They must've been really struggling to provide the current required to get that hot, so the first thing that comes into my mind is bad ripple; and Patrick has said before that high voltage ripple from overstressed LiPos can kill an ESC.
Just an idea, but given that there haven't been any other V3 failures...I'm not sure the MMM is at fault here.
NickRummy 10.30.2008 08:00 AM
My only question is why stress a speed control only hoping that built it safety features save it? Asking for trouble if you ask me.
Those 4800 packs are 25C const. and 35c burst I believe? I'd say you were definitely punishing them! That thing had to be a bullet on wheels while it was running....
skellyo 10.30.2008 08:47 AM
I'm going to have to side with the others here. Running a 2700kv motor on 6S and gearing for 80+mph is just crazy.
