-   -   help? 8xl and bk 7018? (https://www.rc-monster.com/forum/showthread.php?t=1624)
highflier 11.24.2005 12:08 AM
Hi all,
I have a 7018 controller, I want to convert a e-maxx to brushless.
Can I use that controller with something like a 8xl?
I also want to start with the current packs 2 x 6 cells total 12
Will this setup work?
What performance will I get compared to stock setup?
I have hotbodies 7" wheels. what pinion should I use?
Highflier
PS. If this setup will work, Later I will upgrade to a 9920 and step up to lipos.
coolhandcountry 11.24.2005 09:23 AM
If you gear right the esc should be ok. I can run a 7020 on a 9xl with no problems. I would go for a 18 to 1 ratio final drive. Which is about stock.
highflier 11.25.2005 12:57 AM
Hey Coolhand,
Hmm,
How would a 9xl performance be on 12 cells?
I was thinking 8Xl so that I would not have to worry about getting voltage up to get any performance out of the setup.
Highflier
highflier 11.25.2005 12:59 AM
one more question?
I have a amp meter I use on planes. But how does everybody check there amp drawin cars/trucks?
Highflier
coolhandcountry 11.25.2005 09:21 AM
http://www.rcpics.net/view_single.php?medid=67100
here is a video of a 9xl on 12 cells. They have a device to plug into the wire and tell you the info on amp draw watts and other stuff. I don't remember the name of it. Batfish was the source of info.
Sylvester 11.25.2005 10:59 AM
Do you guys think the 7018 is the best controller for a 9xl? I know that a 9920 would be better, but maybe if you want, highflier, you can sell (if you dont need it for another truck) your 7018 and save up a bit and get a 9920?
squeeforever 11.25.2005 11:34 AM
coolhand, i think your thinking about either the "watts up" meter or the eagle tree data recorder.
highflier 11.25.2005 02:26 PM
I know that the 9920 would be better, Guess I am just cheap... I got the money just don't like spending it. The 9xl had plenty of powerin the vid, Was that 1st or second gear? I could not really tell what top speed looked like, hard to tell in vids, Any idea of how it compares to the stock titans on 12 cells?
Highflier
