Brushless Controller
Is this anny good Castle Creations Phoenix-110 High Voltage ESC Brushless controller.
http://www.castlecreations.com/produ...nixhv-110.html For a car controller? |
I emailed Castle, and their advise was not to use it in a truck...
I don't understand why though, a controller with a heatsink, what can go wrong..? I just called them, got their answering machine.. what is liked to know is if this controller is able to work in a savage with a mechanical brake.. (forgot to ask them than in the email) |
The only thing is that it has no reverse!!
WHO CARES!!!??? In the land you're living you don't need it to go reverse.. ;)
Maby that is why they don't recommend it?
I will find out..
You can put 36 cells or 12 lipo's on it
And a continuous 110amps not bad for that price it looks cool to.:cool: |
If you race. You don't supposed to use reverse. If in a savage with the reverse servo you still have reverse.
Airplane controllers shouldn't be used since they aren't made to handle the high peaks that a car will experience.
hahaha - dont scare me like that!!! Just got the 160/24 for the LST! -lol-
It is in the behaviour of the FET or transistor to handle peaks. Normally airplane controller are not suitable, because they don't use a heatsink.
*gets down on knees and starts praying*
Where can i get a heatsink to fit my 160/24 and how do i attatch it?? -lol- |
Since Mr. Constructor was the one that recommended that controller, it should be fine. It can take 160amps continuous, which is a LOT. It can take higher peaks. If you could get a fan running over it, it should be fine. You would have to cut the heatshrink and using thermal epoxy to get a heatsink on.
I emailed Castle a few months ago about this controller. I was told that the warranty would be void if it is used in a monster truck. They also said they have never tested it using a pistal grip radio.
One of the features listed is: Quote:
If you do get one, let us know how it works out. |
i say go ahead and do it! take teh risk since u bought it already. If it works, u got a awesome car controller! and then we can all follow in ur foosteps! if it dont! then u got a smoldering pile of plastic! Oviously, the positive would outweight the negative, since ur helping ALOT of peple.
| All times are GMT -4. The time now is 03:36 PM. |
