WTT: Neu 1512 2.5 D/F
I bought a Neu 1512 2.5 D/F thinking I was going to use 4s for my conversion. Well, things have changed and I have decided I want to use 6s. I would like to trade for a 1512 3 D/F or a 1512 3.5 D/F.
You can email me or call me. nik77356@yahoo.com 936-827-2724 |
Just to let you know, MTXMUGEN on here can rewind the motor to a different KV.
Thats false, he has never rewound inrunners..i he bought my old 8xl to attempt, but never did.
We talked yesterday and he said he was able to rewind an 8xl.
I stand corrected. Sorry for the off-topic
Edit- talking to him now, says that he found out how to but has not. |
I would rather just go with a different motor than to have mine rewound to a different Kv
Why not just run the 2.5d on 6s but just gear down?
Brian, you may have misread. 6s with a 1512 2.5d is 45,510rpm... A bit high.
No, I didn't misread. I know it's a bit higher than most people normally run, but it'll work fine. Someone posted efficiency graphs on the Neu motor and they hold pretty good efficiency up to around 57k rpm. As long as the gearing is kept reasonable, amp draws would be about the same as a lower rpm motor geared higher. The amount of work doesn't change, just how you get it...
Thats what I do, but I would rather run a lower Kv motor and gear up. It will also help with chassis balance.
Same motor size and same lipo size, just different pinion size so what's the chassis balance problems:neutral: |
a bigger pinion will put the motor farther off center making it more equal to the heavier battery weight on the other side.
how old is the motor? |
It has only been run for a couple of months. My friend had it for his 6s setup and then went to a different motor and sold me this one.
| All times are GMT -4. The time now is 08:54 AM. |
