BL Savage Gearing
Right now I have my 7XL running on 18 cells with a 12 tooth pinion. I'm running 40 Series Moabs and an MBX transmission with a 51t spur gear. I'm a bit overgeared I think with this current setup, when I switch over to my 10XL should I change the gearing a bit? I was thinking that since the 10XL doesn't run as hot it will be less overgeared.. Any suggestions appreciated.
try it an just check the temps although, i think that your right. the 10xl on the same amount of cells can take a higher gearing.
What ratio is your savage with that mbx transmission?
I actually don't know, but the MBX transmission's ratio is 44/14.
so a 3.14 to 1 ?
I actually don't know how exactly to calculate final drive ratios, I always just gear by feel, temps, and instinct!
Just post the gears that touch eachother..
Do you mean the pinion and spur? I'm running a 12 tooth pinion and 51tooth spur.
| All times are GMT -4. The time now is 10:44 AM. |
