-   -   MMM V3 dead (yep another) (https://www.rc-monster.com/forum/showthread.php?t=16327)
Basso 11.03.2008 07:57 PM
Well mine was a little different than the others but I thought I'd share. Plugged in and all was fine, then after about 2-3 minutes it starts cogging badly, even at high speed. Turn off reprogrammed Tx-Rx good for 2-3 min. Anyway went through every possibility troubleshooting to no avail, Castle suggested trying a BEC while I wait for a new one. Still the same, but after a couple goes at it, the Monster perished completely. So that was my 3rd Monster (2 V2s and 1 V3) hopefully 4th time is a charm.
Sorry no smoke or fire or high speed braking, just a slow stuttering death.
BrianG 11.03.2008 08:18 PM
I would have checked all the connections personally. Sounds like there was a high-resistance joint; either a cold solder joint or poor bullet connection.
e-mike 11.03.2008 08:47 PM
well i hope:whistle:
hootie7159 11.03.2008 09:02 PM
Thats what mine did way back in May ( my V1 ) then I checked the joints and found a loose bullet that was masked by the heat shrink....now I've got countless hours on my still functioning V1.....with the fan mod and BEC....tried it yesterday with the new update w/o the BEC and with fan plugged back in and is working good so far....
Basso 11.03.2008 09:56 PM
Trust me I checked all the connections + everything else possible and not so possible, the last thing I wanted was to send this back!! Anyway it didn't act like a loose connection, it acted like the TX/RX freq was drifting, I tried 3 different radios and 4 different rx (FM +AM) but no matter what set up I had the Monster would start acting up after a couple of minutes but I could run my MM with no problems. I tried different motors, all new wiring etc, etc, etc up until the V3 gave up completely.
plaviblue 11.03.2008 10:39 PM
Could also be the terminals touching the heatsink. As soon as I got my 2- v3's in I checked for clearance. Both had terminals that were touching and both had a small section of fan wire that was bare. I fixed both before using them.
e-mike 11.03.2008 11:07 PM
so i have 4 mmmv3 and im really hard with it...:lol:+one hour on each unit...could it be your motor?????i just push the limit on each esc:whip:(respectively) and nothing...:yes: both of my v3 still going strong....anyway now the count is four death mmmv3 :grrrrrr:
4 died on how much made????
e-mike 11.03.2008 11:13 PM
i don't think that is the issue...ive try to ''spark'' a old lipo pack on my anodized mamba max heat sink and nothing happen...the anodized aluminium doesn't conduct the electricity ...well after a lot of try nada....nothing
BrianG 11.03.2008 11:18 PM
No, an anodized HS won't easily arc, but if enough rubbing occurs where the anodizing wears away exposing the bare aluminum, there could be problems.
e-mike 11.03.2008 11:21 PM
right...could happend on a new mmmv3????strange!!??the heatsink still new why could it be rubbing??
BrianG 11.03.2008 11:43 PM
Dunno. Patrick said they tried to recreate circumstances where the HS shorts out but were unable to.
e-mike 11.03.2008 11:46 PM
right...:yes:
anyway im still thinking that the v3 look to be stronger that the previous version
BrianG 11.03.2008 11:47 PM
Don't get much runtime, but my V1 still works! :smile:
e-mike 11.03.2008 11:48 PM
mine to and no mod on it:yipi:
e-mike 11.04.2008 12:10 AM
so im really curious to know what happen with these unit(4 mmmv3 failed)
