-   General Nitro (https://www.rc-monster.com/forum/forumdisplay.php?f=13)
-   -   Tuning (https://www.rc-monster.com/forum/showthread.php?t=1633)
Sylvester 11.25.2005 01:56 PM
Tuning
Why is it that for these little motors such as a trx 2.5r, you always have to tune after every run? In normal motors you dont have to touch them at all?
rchippie 11.25.2005 02:04 PM
If you use a quality fuel & if nothing is wrong with your motor you should'nt have to retune after every run.
Sylvester 11.25.2005 02:06 PM
Thanks, buy you HAVE to tune if the weather temps change right?
rchippie 11.25.2005 02:13 PM
Only a little usually you only mess with the end needel.
Sylvester 11.25.2005 02:24 PM
Ok, thanks.
nbcaznmaster 11.25.2005 06:05 PM
bigger the engine, the easier to tune, smaller, the harder. Thats why teh nitro m18 is abadd idea! no1 will wanna tune it.
Sylvester 11.25.2005 06:32 PM
Thanks for the info guys.
nbcaznmaster 11.25.2005 07:20 PM
got temp gauge right?
coolhandcountry 11.25.2005 07:47 PM
I thought the tune ablity was more on the motor design not the size. I have heard that the thunder tiger with th .70 in it is hard to tune as well.
nbcaznmaster 11.25.2005 07:58 PM
well, on average, the big block motors are easier. I was messing with my freind's savage, adn his engine was SOOO easy to tune... compared to my 2.5
squeeforever 11.25.2005 09:01 PM
i dont know what ya'll are doing but a acncm head makes it the easiest thing in the world to tune. not to mention you can lean it way out and it will still only run 230. it helps the runtimes to. i get about 45 secongs to a mintue more time per tank than most. alot when your racing.
-corey
Sylvester 11.25.2005 10:29 PM
How much is that acncm head cost?
squeeforever 11.25.2005 11:06 PM
i paid 40 shipped on ebay. they gurrentee a 50 degree drop.
-corey
Sylvester 11.25.2005 11:51 PM
Why is that, is it just because it is bigger in size? Or different material used, or somthing else?
squeeforever 11.25.2005 11:59 PM
heres some pictures. IT IS HUGE! you will have you trim your body a good bit.
-corey
