1/8 scale buggy project
1 Attachment(s)
Here is the start of my project. Still lots to do.
1 Attachment(s)
Another.
Steve looks great so far. Is that a mugen mbx 4 or 5 ?. Have you seen mine ?. The thread is titled hippies bl mbx4.
Steve what motor is that ?. |
That's a nice 4 you've got there! Looks really clean.
That is a 4. The motor is an old Aveox 1412/1.5 turn. The motor still maybe changed. Yes I have seen the hippie and I hope mine comes out as nice as yours.
nice setup. Im not suprise if urs does. How u gunna setup ur batts? Hippi style?
Speaking of batteries how many cells are you running?
Not bad! Would you care to share some close-ups of your motor mount? :)
1 Attachment(s)
One.
1 Attachment(s)
Two.
Steve were did you get the motor mount, & what center diff is that ?.
PS If i can help in any way just ask. Are you going to run lipo's or regular batts ?. |
Looks great!
You really need a hardened pinion on that motor, the normal MOD1 gears will be shredded within 2 runs. Where are you going to drop your batteries? here is the conversion of a HB lightning Pro i did. |
Hippie, I designed it and my friend cut it with a wire for me. The diff I am not sure, but it has MBX carved into it.
Serum, where do I get the right pinion? I am either going to run a 4s4p 2500 tanic pack or a 6s4p 2000 TP pack and change out the motor. Thanks for the compliments! Steve |
I changed the spur tp a plastic one. Mike has got all the pinions i use.
I haven't had much luck finding a hardened pinion either, you should try to make an adaptor plate to mount oine of the ofna 51t plastic spurs, like hippie did.
| All times are GMT -4. The time now is 08:01 PM. |
