How Do You Replace Ultra Shocks (EMaxx Stock Shocks) Shafts?
I can't seem to find a way, I'm just uberly retarded... :lol:
Help... anyone? Can't find it in the exploded diagrammys. P.S. I like these shocks with my Trinity XXX springs, so no upgrade.. yet:oops: |
Take the cap off and the plastic end off the shaft and push it through the body...
Reverse for assembly. |
The shaft is bent =/
And how do I remove the rod end? |
Hold the shaft with pliers and unscrew the rod end.
As far as the bent shaft, should I attempt to cut it with some cutters?
Alright, thanks!
Looking forward to rebuilding the maxx later tomorrow -.- 10:48, can't function!! >_< |
remove the shock cap.
remove the shock end slide the shaft with piston up from the shock body. remove two E-clips holding the piston and you got just the shaft |
http://www.traxxas.com/PDF-Library/3905_front.pdf Exploded view. http://www.traxxas.com/support/kb_se...cat=165&id=518 Traxxas manuals.
Thanks a ton for that diagram Rnemhrd!
I took it apart in the sink, and remembered that in the diagram (took a close look before taking it apart) that there was small parts, and in the middle of taking it apart, I shut the drain, and that was when the small tiny eclip fell off... Whew! Got it working, hopefully 40WT w/ Trinity XXX Hard Springs should do it. Hate bottoming out! |
I would save up some cash and upgrade the shocks. Use the forum search to see what the guys are using, what not to use, and how they perform.
I'm gonna get some 1/8 XTM or UE or Ofna shocks when I get some extra cash.
Until then, the shocks right now are just fine for my appliance. |
| All times are GMT -4. The time now is 06:23 AM. |
