Mamba Max w/ Fiegao 9L - Series Harness? Or what?
I can't remember correctly.
I believe it's the series harness? Where, the female deans/connector goes into the male ESC deans/connector, and the female deans/connectors is split into two deans? Anyone have a good diagram? Or should I just pick one up from like GA? |
So I'm looking for the series right?
Does the postive and negative go together.. right? |
For now, NiMHs, but have some hardcased 5000mAh 2S ones on hand. That I should be testing out sometime tomorrow.
Also included 3A-5Amp UBEC.
Now, I'm completely new to the brushless world, but what does the UBEC accomplish? And how do I wire it? With the diagram, I'm viewing that I should be splicing it into the ESC's Male Deans? |
anyone?
Are the series harness the same, even with NiMHs?
and Quote:
This is not the Traxxas forum.... :whistle:
Read one of my FAQs, then the tutorials that follow them in the same threads- that will answer all your noob wiring and BEC etc questions in explicit detail :yes: :mdr: |
Too true Neil.
Actually, mikey said that, up above. Quote:
Actually Neil, since I'm only going to be running the 2S (x2) LiPos, I won't be needing the UBEC, will I?
Of course, if I was running 4S, I would need it. Or is running 2 lipos in series doubling the cells, thus causing 4S? Or am I just gone stupid. |
You dont need to read the whole thing, there are seperate sections relating to the different issues you are asking about.
2 + 2 = 4. Series doubled the voltage, parallel doubles the mah. You will need: A UBEC / BEC. A capacitor equal to 25v 105*C low esr 2000-4000uf. A series Y-harness for the 2x 2s lipos to be wired together IN SERIES. Yes, you are stupid, now go away before I fart on your head. If you skip to the lipo tutorial, it explains what you need to do, as does the BL upgrade section in the FAQs. Its all good... :yes: |
| All times are GMT -4. The time now is 08:29 AM. |
