Crt.5 extended chassis and servos
Do I have to use fullsize servos on the Ofna extended or RCM extended chassis or can I mount the current miniservo without extensive modding ?
(IŽd like a larger chassis but dont have funds for a new servo just yet) /Emil |
I am not sure about the RCM extended chassis, but I know on the Ofna extended chassis, that there are no mounting holes for the mini servo; unless you drill them yourself that is...
Thanks anyone that knows about the RCM chassis ?
The RCM chassis is drilled for standard servos. You could probably rig something up, but even a $40 standard servo would be a lot better than a mini.
Thanks guys, you convinced me as usual, now if Mike can just get it in stock....
| All times are GMT -4. The time now is 08:49 AM. |
