Blue rc-monster motor heatsink
Hello,
I read a while ago that the motor heatsink would be also avalible in blue, i just wonderd if its avalible yet ???? Thanks |
Another week or so and it will be. Only the "L" and "XL" for now, though
Are you making a longer one for the XL instead of just the longer screws too?
As far as I understood, there will be a true XL version. It covers the hole lenght of the motor, no need for long screws.
OK how long for the full length XL version ?
thanks |
I would like a couple xl versions. I am not sure on color. Maybe a combo.
I m out of the "L" version at the moment. Next week, I will have both the"L" and the new "xl" versions in stock. In silver AND Blue.
Nice one Mike! I've always liked those heatsinks, and in blue they'll look killer. :D
Will the Xl completely cover a 1940?
It will be 71 mm on the under side papa. I am not real sure what a 1940 has length wise. I think it is a touch shorter.
The 1940 is 66mm. Sounds too long. But then again maybe longer is better?
I run a 1930 papa with no heat problems what so ever. I don't have a heat sink on it and it runs about 100 after a full charged pack.
So the XL will completely cover a wanderer XL ?
Yeap that is what it was design for guerilla. Instead of using the L version with long screws.
OK thanks, should look good, guess ill have to order one from mike when i get my motor ect, though thats a little way off as i still need to order my chassis
| All times are GMT -4. The time now is 04:24 AM. |
