Castle connector ?
I just installed my castle 5.5mm connectors on my neu motor & castle esc & i noticed something. when put the two plug halfs together there is a small gap between the two ends . I pushed as hard as i could but they will not go on anymore . Has anyone else noticed this ?.
I do not have the 5.5 but the 6.5 do not do it for me...
do you think i should use them or get another set ?. The gap is about 1/16th . |
This blows . There a brand new set that was sealed in the bag . By the time i pay shipping a new set is going to cost close to $15.00. |
Check for any burrs on the plug or in the socket...
there are no burs . The female plug is 9.92 mm & the female plug is 10.18mm . |
Are they all that way, or just one of them? I would think that as long as its secure and you have the full contact of the plug it shouldnt be a problem. I'd run it.
I don't see any issue with it. I'm disappointed with the female plugs on my new v3. Most of them are extremely loose. I am going to have to spreadt the tongs on the male connectors.
If you are getting a good fit/connection, just re do the heat shrink and slide it up a bit.
MT: i was told we ARE allowed to solder the females DIRECTLY to the MALES on the MMM plugs. i have had issues with this looseness thing and when i get my new controller back i will fill the gaps up with solder. aparently the guys testing the escs have been doing this....sounds like more resistance and more of a pain than a wire!! o well...
heres the email he sent: Quote:
That's really weird...all of my 6.5mm connectors have a really tight fit. So tight, that I have a hard time pulling them apart lol, but they provide excellent contact. Perhaps Castle need to work on their tolerances a bit.
Bernie at castle & mike at rc-monster said thats sinice im getting full contact & that they are fitting tight , not to worry about it . Just redo my heat shrink to cover the exposed area .
I'd suggest you call tech support and just get them to send you an AWR. Tell 'em Patrick sent you. |
patrick this was acctually my comment . it's all good . I talked to bernie the other day . He said sinice im getting full contact that they are safe to use . but he is sending me another pair just to be sure . thank you for having great customer service. :smile:.
| All times are GMT -4. The time now is 03:26 AM. |
