wich Motor for Hyper 7 Conversion?
hi,
wich motor is good for a hyper 7 conversion with a mmm and 6s2p a123 cells? http://www.hobbycity.com/hobbycity/s...idProduct=6678 http://www.bidproduct.com/part/Produ...MOTOR_184.html http://www.bidproduct.com/part/Produ...MOTOR_183.html i think 1700rpm/v is a good choice. will a xl give a shorter runtime than a l? |
None of those motors are good enough IMO to run, Feigao on 5s will run hot, those are the same if not lower quality.. i would looks into at least a feigao or a nicer motor like a medusa
My vote is this one for 5s.....
http://www.rc-monster.com/proddetail...2_2.5df&cat=20 or if money is a bigger concern, this one... http://www.rc-monster.com/proddetail...usa3660&cat=20 The Neu is a better motor, but the Medusa is also very good and a bit cheaper...in motors, YOU GET WHAT YOU PAY FOR |
I have a 1600 kv medusa 60mm motor for sale, would be great with the 6s2p a123. Check the motor sale link in my sig below and pm me if you are interested...
If you don't get Linc's motor, go for the 60mm Medusa. I'm dropping a 70mm in mine because I'm a crazy bastard that likes everything overpowered :party: but I've heard anything more than a 60mm Medusa or Neu 1512 is a waste in a Buggy. For a Feigao or other cheap China motor a 14L on 6s should be OK if you gear down. I've got a 6XL in my Hyper 7 until my 70mm Medusa comes in and it seems to do pretty well. |
ok, the neu motor is too expensive for me :(
i think i will go with a bidproducts motor. another question, is is recommended to put 2 a123 packs with 950g in a buggy? i think this is really heava for it, but i wanna use a123 for the fast charging times. |
i will use it on our racetrack.
maybe i sell it and buy a st-1 (truggy) roller. |
i will use 2 packs with 6s simultaneously.
i hope for at least as 15-20 min runtime. same packs i will use for my lst2. |
| All times are GMT -4. The time now is 08:21 AM. |
