-   -   confused about diff fluid (https://www.rc-monster.com/forum/showthread.php?t=16614)
bustitup 11.16.2008 01:18 AM
best fluid to use for crt on a clay track....just broke a rear cap joint probably from a jump landing
i'm running a 1515/2.5d on 6s geared 12/62 MMM ......truck wants to pull the front wheels slightely
just use naptha to clean the gears? and dry off with paper towels?
Arct1k 11.16.2008 09:27 AM
Try 7 20 3
stum 11.16.2008 10:30 AM
I run 7/30/5 with my 8ight-t on a similar surface
GREYGHOST 01.23.2009 04:37 AM
If you mix equal amounts of 50k and 10k would you then have 40k?
stum 01.23.2009 07:51 AM
50 + 10 = 60 /2 = 30k So no.. w/o doing the math I'd do about 25% 10k
BrianG 01.23.2009 11:20 AM
Equal parts of 50 and 10 gets you 22.5. It's not just getting an average. The formula is:
mixfluidA = ((log(targetvisc) - log(viscfluidB)) / (log(viscfluidA) - log(viscfluidB)) )
mixfluidB = 1 - mixfluidA;
To get a 40k mix, you need 86% of 50k and 14% of 10k.
GREYGHOST 01.23.2009 03:19 PM
This should clear things up.
Calculating the viscosity of a blended liquid consisting of two or more liquids having different viscosities is a three step procedure. The first step involves calculation of the Viscosity Blending Index (VBI) of each component of the blend using the following equation (known as a Refutas equation):
(1) VBI = 14.534 × ln[ln(v + 0.8)] + 10.975
where v is the viscosity in centistokes and ln is the natural logarithm (Loge).
The second step involves using this blending equation:
(2) VBI-blend = [wA × VBIA] + [wB × VBIB] + ... + [wX × VBIX]
where w is the weight fraction (i.e., % ÷ 100) of each component of the blend. In using the above blending equation, it is necessary that all viscosities are determined at the same temperature, for example, 100 °C.
The third and final step is to determine the viscosity of the blend by using the invert of equation (1):
(3) v = (ee(VBI - 10.975) ÷ 14.534) − 0.8
lincpimp 01.23.2009 03:54 PM
To sum things up...
It is best to just buy the correct fluid, as reading the last 2 posts has given me a headache.
Considering you have slight tendancy to wheely, you may have about the right fluid in the center diff now, maybe a bit too thick. If the front tires are growing huge the fluid is too thin, and if the truck wheelies then the fluid is too thick. I think some front tire growth is acceptable, as it will help pull the truck around corners. The pro nitro racers run light fluid, and go thru a set of front tires in a single race... I noticed this when looking at the race action pics in the rc mags, and checking out the racer's riders section they usually do on the national race winners.
I run thicker fluid as I like wheelies (no racing for me!) and really like tires to last...
cheesecake 01.23.2009 09:40 PM
i asked chad bradley this question on neobuggy he said 20-30-1 i ran that the whole time i had my crt and loved it
hoovhartid 01.23.2009 11:56 PM
if you want 40k, you need 86% 50k and 14% 10k.
http://www.gesilicones.com/gesilwiza...ng/fluid2.html
BrianG 01.24.2009 01:20 AM
That's what I said earlier. :wink:
BTW: I have that same calculator at my site. I just viewed the formula the script uses and added my own error checking and such. Since it is directly based from that gelsilicones site, I put credits at the top of the page.
JERRY2KONE 01.24.2009 01:43 AM
Me to
You beat me to it James:diablo:. I was thinking that exact same thing as I started reading their posts:eyes:. If you have to work that hard to figure something like what portions of each grease to mix in order to get the right concoction for your setup:oh:, then it is time to just spend a few dollars and get the right grease in the first place:diablo:. What a brain twister that is.:oops:
Thats what I love about this site though, is having PROs like them to answer a question like that, and then have guys like us who say just buy the right thing up front and avoid frying your brain.
hoovhartid 01.24.2009 05:36 AM
oops, I missed it the first time. I just scrolled back up and saw it...my bad:oops:
cool that you added it to your site tho.
GREYGHOST 01.24.2009 06:21 AM
Guys....easy....the 50k -10k thing was meant as a joke! I only quoted some professor's explanation of the formula when someone else did it too.....I thought it was funny....:sarcastic::sarcastic::sarcastic:
JERRY2KONE 01.24.2009 06:49 AM
Yea funny stuff.
Yes we thought it was funny to, that was the point. :lol::rofl:
