-   -   Ground BL motors?? (https://www.rc-monster.com/forum/showthread.php?t=1662)
Dafni 11.29.2005 02:59 AM
Ground BL motors??
Folks, something to discuss here. BK now supplies a short manual with their motors. They mention that if you have interference caused by the motor (?) you should connect the motor screws to the minus of the batts, so to say ground the motor!?
How about that? They say this should be done especially on CF hulls.
What do you think? Connecting the minus to the chassis??
dabid 11.29.2005 03:47 AM
Sounds like a bunch of hooey to me! :L:
E-Traxxer 11.29.2005 04:20 AM
Well, it sounds like a bunch of.. KABLOOEY to me! :L:
Traxxas does ground their EZ-Start system to the motor mount though..
Rtsbasic 11.29.2005 07:50 AM
Mtroniks brushless controllers use a schottky diode between each motor connector and the -ve battery terminal. Something similar?
crazyjr 11.29.2005 08:28 AM
Real cars have grounds everywhere to cut down interference on radios so it makes sense.
nbcaznmaster 11.29.2005 09:42 AM
True, but this is a first for bl motors. Well, I havent experienced any inteference, unless the Bk glitches more then feigao
Serum 11.29.2005 05:24 PM
perhaps it is more about staticl electricity! That would make sence. I can't imagine they believe a .5mm thick aluminum/cf shell is able to keep any radiation inside when isolated on this way..
Dafni 11.29.2005 05:30 PM
But wiring the minus to the chassis or motorscrews??
Serum 11.29.2005 05:33 PM
static electricity...? think Einstein...
Dafni 11.29.2005 05:39 PM
Sure, I see. But I just don't like the idea of wiring the batt directly to the chassis.
Here is what the short manual says (and, yeah, it sounds kinda weird in german, too):
--If you experience interferences from the motor over the controller, please connect a 1.5m2 wire from the motor (screws) to the batt minus, thus the motor is grounded. (often recommended on CF hulls)
The german text is somewhat confusing, too. Really.
DAF
crazyjr 11.29.2005 05:55 PM
I don't see a problem with a little more securityagainst interference, it may also increase range by reducing EMF from the motor.
nbcaznmaster 11.29.2005 06:26 PM
hmm, could u do that with other motors?
Serum 11.30.2005 06:52 PM
you think that that thin piece of aluminum is capable of reducing any EMF, just by connecting it to the ground?
mmdooley 11.30.2005 08:38 PM
I can't see how the aluminium chassis could ground the motor very well. And what will grounding do to the other electronics attched to the chassis??
Dafni 12.01.2005 11:02 AM
I wonder what Mike has to say on this!?
