Brushless RC8T gearing?
so i am building a RC8T and converting it brushless. i have notice that the spur gear on the T is a lot larger than the buggy spur gear. why is this? i have a losi 8 and 8t that are both brushless and both came with 13/48 gearing. i think the RC8T spur is like 54t. i am wondering since i am converting to brushless if i could goto like a 17/50 or a 13/46 setup and be ok for temps? i have 15/48 in my 8t and it screams but temps are great. i dont know what the front and rear gear ratio is in the RC8T though so can anyone recommend the best gearing.
this will be setup with a Tekno Neu 1515 1.5D 2700kv and 5s i like to go fast. |
holy crap james! a 1.5d on 5s in insane! i would guess that you would need to gear to your track if your racing
Ring and pinion are 43/10 and a 2700 motor on 5s is way overkill
with that motor on 5s with a 13 tooth pinion your speed would be 48 mph on 4s which is were you should be with that motor puts you at 38 mph |
Here is a chart jhautz made for me. i have changed it a bit but its rc8 on the left rc8t on the right just put in your info needed and it will tell you how you should gear it
http://spreadsheets.google.com/ccc?k...IXb3oiedTTqUeQ |
i keep seeing this info (see below) posted around. how do i get my hands on this calculator and can anyone that might have it run a couple of figures?
what is the speed of a Losi8t with 15/48 gearing and 5s on 2700kv? and what is the differential ratio on the RC8T? i will be running the same 5s on 2700kv and want speeds similar to my losi8t. (sample from another thread) Differential Ratio: 4.3 Transmission Ratio: 1 Other Ratio: 1 Spur Tooth Count: 48 Pinion Tooth Count: 13 Total Voltage: 14.8 Motor KV: 2700 Tire Diameter (inches): 5.8 Tire Ballooning (inches): .2 Motor Current Draw: 0 Motor coil Ω: 0.004 Spur/Pinion Ratio: 3.69 : 1 Total Ratio: 15.87692 : 1 Tire Circumference (inches): 19.48 inches (494.74 mm) Total Motor Speed: 39960 RPM Vehicle Speed: 46.42 mph (74.57 km/h) Estimated Adjusted Speed: 44 mph (70 km/h) - 6% loss Effective KV Value: 2700 KT constant: 0.5 oz-in/A Motor Torque: Amperage not specified... Final Torque: Amperage not specified... Final Power: Amperage not specified... |
Here you go http://www.scriptasylum.com/rc_speed/index.html
thanks Matt, i knew my losi 8t was fast but i havnt been able to radar it. this is telling me 82mph. i actually estimate it being about a 65-70mph truggy. cant wait to get the RC8T going. now i know which gears to run. as far as my setup being overkill as others have said.....my reply? "to each their own." |
| All times are GMT -4. The time now is 05:18 AM. |
