Max Amps 4000 vs EFlite 5350
I have 2 or 3 questions please give me your input guys.
1. I am running a max amps 4000 now and want to move up to a 5000 pack what should be the mph diff between the 2 packs 2. is there a big diff between runnin a pack that is an 18c and 20c? 3. If so will the extra MAH help to make up for the loss in continuous discharge Please advise.. Thanks |
No experience with the eflite but the maxamps pack is not a true 20c pack...
I would suggest to go with a polyquest or neuenergy 5000 pack, they will easily outperform the maxamps pack, and most likely the eflite too... |
Polyquest and Neuenergy
Neuenergy packs are sold out and the Polyquest packs are too long
Ok, what are you running this pack in?
they are being run in a touring car.. space is pretty limited
So many questions.. what voltage, what application etc etc some specifics would help. The new maxamps packs are suppose to be pretty darn good, but who knows (30,35c ones). Elite 35c 5000mah packs are the best lipo's I've ever used and that includes the Neu 5000's the Polyquest, the SMC 28c, the Evo25's and a few others! Do you race? Do you need hard packs? Lots of things to consider when choosing.
I dont need a hard pack its for a speed application im running a mamba monster and a lehner 5000kv and some pretty low gearing 34/60
Main thing is what would i be missing between looking at an 18c and a 20c that has less mah
| All times are GMT -4. The time now is 01:31 AM. |
