Are Losi thread on pinions hardened?
I am wondering if the stock thread on pinion gears that come with a LST2 clutchbell are hardened? I know that they are used with plastic spurs.
I only ask as the tin coated pinion gears seem much heavier than the stock ones. Just checked with a magnet, and the stock losi gears are al... That sucks. I guess I will have to buy a few hardened ones from Mike. Any other info is welcome! |
Hello.
That is my info. |
Well I cured my own problem. The current 2 speed I plan to use has 46/42 gearing. And the tin coated gears are 18/25. So I did the math and found that I need to run 49/42 to match the pinions I have. So I "modded" a worn out 49t mgt plastic spur and it looks like it will work well. Does anyone know of any 49t steel spurs, preferably not one that fit on a center diff. I will have to cut the inside out to a certain size and the bearing boss and assorted holes will be a pain to work around... |
| All times are GMT -4. The time now is 04:40 PM. |
