LOSI 5s Hard Case
A sign maybe Roar would allow higher voltages...
http://www.losi.com/Products/Feature...rodId=LOSB9834 18.5V 4000mAh 5S 25C LiPo: 1/8 Vehicles At a Glance This 18.5V 4000mAh 5-cell 25C Hard Case LiPo battery pack for 1/8-scale vehicles provides the power needed for competitive racing, while increasing running time between charges. The hard case protection keeps the expensive cells from becoming damaged externally. The pre-wired EC5 connector provides a quality connection and excellent power delivery. Features LiPo pack's protective hard-shell case provides extra safety LiPo power provides increased speed and extended run times Pre-wired EC5 connector provides quality connection and excellent power delivery NOTE: This LiPo Battery MUST be charged with a LiPo Balance Charger. Losi recommends the Intelligent LiPo Balance Charger (LOSB9605 http://www.losi.com/ProdInfo/LOS/250/LOSB9834-250.jpg |
Yikes, 270 is a bit steep... Getting up there with maxamps...
Anyone else see Losi's batteries becoming the ROAR standard?:whistle: I sure hope not, i can almost get 3 zippy 5000mah 5s packs for the same price. |
Not sure if it has to do with ROAR, this battery is the same size as the 4S Losi Lipo so it can be used in the 8IGHT-E
The zippies dont but my track accepts softshell lipo's :D
You're lucky, I went to my local track with a rustler to run in an unlimited class (5s lipo, s can feigao, quark 65, and they said no softy lipos...
Does anyone know the dimensions of the losi hard case packs? I haven't been able to find them, losi doesn't seem to give those sort of specs :whip:
The specs are:
overpriced X overrated X overmarketed. |
| All times are GMT -4. The time now is 09:37 PM. |
