Balancing Nue batts with TrakPower v-balance
How do I balance a NeuEnergy 5s battery with a V-Balance from TrakPower? Is it as simple as plugging the NeuEnergy's tap into the V-Balance?
The NeuEnergy has a 6 pin female tap. The V-Balance has an eight pin plug. Should I put the tap close to the positive lead Like the TrakPower tap. That way the black lead will be on the same pin? Thanks |
Well, neuenergy lipos use kokham taps, IIRC. And the v balance is setup to use fp adapter pigtails, not sure if they make one to go to kokham taps.
With some modding you could make this board work: http://www.amainhobbies.com/product_...ducts_id/28927 but you also need the cable, which only appears to be sold with the polyquest board: http://www.amainhobbies.com/product_...ducts_id/20719 I have everything listed, I can try to make it work tomorrow and let you know... |
:sleep:You were up late.
Thanks for the reply. The pig tail on the V-Balance can be unpluged. When I do that the balancer itself then has an eight pin male plug. I might not have to modify anything if I just knew what the pins were for. The Neu tap has six female pins. Can it be as simple as just pugging it in? |
I was up to 3am, went to the Metallica concert last night and got home late.
Here are a few pics. I just plugged the adapter harness in and left the 8th pin (closest to the pos charge lead) exposed. Works fine with a 3s pack, I do not have a 5s pack to try. http://i206.photobucket.com/albums/b...p/DSCF2780.jpg http://i206.photobucket.com/albums/b...p/DSCF2781.jpg http://i206.photobucket.com/albums/b...p/DSCF2782.jpg |
Thanks. I'll try tonight without the adapter. I'll let you know what happens.
I wanted to go but family obligations got in the way.:cry: Were they good?:party: |
Well it doesn't fit without the adapter board....
| All times are GMT -4. The time now is 12:27 PM. |
