-   -   CC 2650kv on 6s? (https://www.rc-monster.com/forum/showthread.php?t=16822)
shaunjohnson 11.24.2008 03:38 PM
CC 2650kv on 6s?
will it take it?, i plan to run 4s nearly all the time but when i feel the need i have 2 8000mah 3s lipo's here that i may strap it:lol:
for speed runs only..bashing i will see striped diffs:lol::yipi:
bl-is-future 11.24.2008 03:40 PM
it will handle a few speed runs but i wouldn't push your luck with that high of a kv motor.
shaunjohnson 11.24.2008 03:43 PM
ok thanks, just watch the temps right?
what's the max RPM of these CC neu motors?
shaun
bl-is-future 11.24.2008 03:55 PM
well the neu's are 60k rpm But the castle may be different. Watch the temps and dont hold it at full throttle for lengthened periods of time. If you constantly run it that high of rpm you cant explode the magnets.
azjc 11.24.2008 08:21 PM
its not the limit of your motor I would be worried about but the limitations of the mechanics, such as drivelines and gears...if you havnt bought the motor yet I would go with a 2200 kv model....unless you really gear the 2600 kv motor down it WILL run hot due to the higher amperage draw
Arct1k 11.24.2008 08:59 PM
I've run the 2650 CC on 5s and it had no issues on the GTP or a buggy - 6s doesn't fit my layout well so I havn't tried that yet...
shaunjohnson 11.25.2008 01:09 AM
will the 2650kv be ok on 4s?
i'll usually be running 4s anyway.
and what gearing should i start with?
shaun
Unsullied_Spy 11.25.2008 01:19 AM
2650: Buggy
2200: Truggy
The 2650 will be fine on 4s, I'd start with a 13T pinion. 6s will be fine as long as you don't hold full throttle for too long. Do NOT free-rev the motor, go downhill at speed, etc. and you will be fine. Considering the voltage drop with the load on the lipos, and the fact you probably won't hit full motor RPMs when used in your Buggy/Truggy you should be fine.
pasan 11.25.2008 04:32 AM
Isn't the 2650 offered in the combo? If so will CC have a warning stating not to run it on 6S, a la Mamba Max 7700 style?
SpEEdyBL 11.25.2008 05:52 AM
Castle has stated you can safely run the 2650 on 6s without harming the motor. The rotors are kevlar wrapped so no harm to the rotor near the 60k limit.
Of course you are looking at speed in excess of 70mph with 6s.
shaunjohnson 11.25.2008 07:58 AM
that's what i wanted to hear:lol:
now i just have to make the diffs last:lol:
thanks for the help,
u guys here really know your stuff:yes:
speedracer1129 11.26.2008 02:38 PM
Shaun,
As long as you shim everything properly, you will be fine!
