-   -   "Tekno RC Axle Carriers and 17mm Adapters" Issue (https://www.rc-monster.com/forum/showthread.php?t=16825)
Smashwings 11.24.2008 06:06 PM
I posted this in the Revo forum because didn't noticed the Tekno Forums, so I copy it here (sry for double posting):
Hi,
I’ve bough the Tekno RC Axle Carriers and 17mm Adapters for the Revo , and when installing it, I noticed that the thurnbuckle hits the plastic parto of the outher ackerman holes and i’m not able to attach it to the steering arm.(see picture)
The hollow ball of the toe llink is in the upper position according to instructions to eliminate the Gump steer in the 15º caster angle position
Anyone knows how is supposed to be attached?
Thank you
http://img156.imageshack.us/img156/3394/cimg2916jc2.jpg
http://img142.imageshack.us/img142/6564/cimg2921qb4.jpg
jhautz 11.24.2008 06:11 PM
I would fix it like I fix everything RC... A dremel tool on the part that is hitting. lol
Smashwings 11.25.2008 09:02 AM
Yes, that's the solution I see too, but didn't thought it would be necessary if designed for a Revo. Looks like a faulty design?
teknorc 11.25.2008 03:14 PM
Definitely not a design flaw. It's more of a tradeoff. Just like not being able to use long travel suspension setup with RPM arms. With added functionality sometimes comes tradeoffs. If you don't think you're going to use the additional Ackerman holes, they can easily be ground off for more clearance as jhautz suggested. You may find that under normal operating it may not be a problem even as is.
If the parts break for any reason due to grinding or other circumstances, just send them back and we'll replace them. Thanks!
Smashwings 11.25.2008 07:49 PM
But RPM arms are third party accesories , and the bump steer correction (hollow ball in the upper situation) is an standard adjustment that Traxxas include for the Revo.
But it's ok , some dremelling will solve it fast, thanks.
Semi Pro 11.28.2008 03:12 AM
its also the adjustment that most of us who race our revos are useing, i think that is going to stop me from buying this kit.
BrianG 11.28.2008 04:20 AM
I know it's not ideal, but you could either flip the hollow ball, or use a different smaller hollow ball and use whatever shims necessary to allow turnbuckle clearance, yet reduce bump steer as little as possible. Either way, it's a tradeoff...
riceman 11.28.2008 10:12 AM
That's a key point you just mentioned. The percentage of people who actually race their Revos I'm guessing is probably less than 10%. The majority purchasing this kit would be getting a definite upgrade in durability and performance with a direct bolt on. And as Tekno has mentioned with slight modification it still accommodates the serious racer setups without affecting strength.
